03-18-2013 10:13 AM - edited 03-19-2019 06:27 AM
Can Unity Connection only connect to one AD domain?
03-18-2013 10:42 AM
For user import you can connect to up to 5 directories, however only a single connection can be used for authentication. Do you have multiple forests or multiple domains? If multiple forests you will need to integrate to MSFT ADAM or LDS, if multiple domains you can simply point to the global catalog's root domain.
HTH,
Chris
03-18-2013 10:57 AM
03-18-2013 11:03 AM
2 domains in 2 separate forests or 2 domains in single forest? In either case see my previous reply for what your options are.
Chris
03-18-2013 11:14 AM
my mistake, 2 domains in 2 separate forests. I will follow earlier posts and update
