08-08-2012
06:03 PM
- last edited on
03-25-2019
09:46 PM
by
ciscomoderator
I'll be uupdating my Cert to HTTPS within the next couple of days - will this require a new license MAC? I've read that the current license file will be good for thirty days after any change - just want to be sure I have a fall back in case the change doesn't work as advertised? Thanks for the help.
JIm
Solved! Go to Solution.
08-08-2012 07:20 PM
Generating a CSR and uploading a certificate does not change the license MAC. Only modifying these items would instigate a need for rehosting:
http://docwiki.cisco.com/wiki/Licensing_Model_for_Virtualized_UC_Applications
Please remember to rate helpful responses and identify helpful or correct answers.
08-08-2012 07:20 PM
08-09-2012 03:23 AM
Thanks for the info, Cisco needs a better way to manage licensing. I hate the software MAC, you never know what's going to change it on you. It's good to know you have 30 days to get a reissued one if it does change.
