What is the SKU in Cisco CCW to order additional PRI port for Cisco ISDN Gateway
David Anstee
Level 4
Level 4
What is the SKU in Cisco CCW to order additional PRI port for Cisco ISDN Gateway?
The Datasheet over here: http://www.cisco.com/c/en/us/products/collateral/unified-communications/telepresence-isdn-gw-3241/data_sheet_c78-626475.html
Says that the SKU is: L-3241-1PRI
However in Cisco CCW if you enter this SKU it errors with "Product cannot be purchased, because it is only available as an option for other items."
I also found another SKU from an Internet Search which is LIC-3241-1PRI however this also does not work in CCW with the same error.
How do you order an 'additional' PRI Port for an existing Cisco ISDN Gateway??
David Anstee
Level 4
Level 4
After further searching on the Internet, I stumbled across the correct SKU.
It is: L-GW3200-UPG-PAK
I would strongly recommend that Cisco updates its Data Sheet with the correct SKU :-)
