Nexus 7010 fabric extender timing out
cbuzzard
Hello -
We have a Nexus 7010 and we are testing out using the fabric extenders for a need.  We have a demo 2224 unit and have it connected to our M132XP-12 10G blade in the 7K but the FEX won't come online.  I would have figured a possible software incompatability but looking at the supported list for that as well as hardware everything seems to be in order.  This is what the status shows after it spends about 15 mins in the image download state.
FEX: 111 Description: FEX0111   state: Offline
  FEX version: 4.2(1)N2(1a) [Switch version: 5.1(2)]
  FEX Interim version: 4.2(1)N2(1a)
  Switch Interim version: 5.1(2)
  Module Sw Gen: 21  [Switch Sw Gen: 21]
pinning-mode: static    Max-links: 1
  Fabric port for control traffic: Eth2/20
  Fabric interface state:
    Po11 - Interface Up. State: Active
    Eth2/20 - Interface Up. State: Active
  Fex Port        State  Fabric Port  Primary Fabric
This is looped in the log details until it times out:
04/25/2011 15:31:41.986978: Module register received
04/25/2011 15:31:41.987713: Registration response sent
04/25/2011 15:31:41.987889: Requesting satellite to download image
04/25/2011 15:32:00.105031: Module register received
04/25/2011 15:32:00.105779: Registration response sent
04/25/2011 15:32:00.105956: Requesting satellite to download image
04/25/2011 15:32:20.191181: Module register received
04/25/2011 15:32:20.191957: Registration response sent
04/25/2011 15:32:20.192144: Requesting satellite to download image
We ran a debug during this and these entries are displayed when looking for errors.
2011 Apr 25 15:30:31.443745 fex: Reg resp: Failed to get card info for swcardid 132
2011 Apr 25 15:30:35.472721 fex: Cardinfo: Unknown card id to get (132)
2011 Apr 25 15:30:35.472753 fex: Reg resp: Failed to get card info for swcardid 132
2011 Apr 25 15:30:41.495302 fex: Cardinfo: Unknown card id to get (132)
I'm still doing some more searching which so far hasn't turned up much, wanted to see if anyone has some other insight??
Thanks!
jacyu2
Did you upgrade the EPLD to 5.1?
Jack
Hi Jack -
Thanks for the response.  Unfortunately, yes that is already complete.  I was hoping that would be an easy fix.  When we upgraded to 5.1(2) we did the 5.1 EPLD.  I ran the install all impact command noted below for the 5.1 EPLD just to make sure it didn't report anything else as needing upgrade.
sho install all impact epld bootflash:n7000-s1-epld.5.1.1.img
Compatibility check:
Module  Type  Upgradable        Impact   Reason
     1    LC         Yes    disruptive   Module Upgradable
     2    LC         Yes    disruptive   Module Upgradable
     5   SUP         Yes    disruptive   Module Upgradable
     1  Xbar         Yes    disruptive   Module Upgradable
     2  Xbar         Yes    disruptive   Module Upgradable
     3  Xbar         Yes    disruptive   Module Upgradable
     1   FAN         Yes    disruptive   Module Upgradable
     2   FAN         Yes    disruptive   Module Upgradable
     3   FAN         Yes    disruptive   Module Upgradable
     4   FAN         Yes    disruptive   Module Upgradable
Copy complete, now saving to disk (please wait)...
Retrieving EPLD versions... Please wait.
Images will be upgraded according to following table:
Module  Type           EPLD      Running-Version   New-Version  Upg-Required
     1    LC  Power Manager              4.008       4.008           No
     1    LC  IO                         1.006       1.006           No
     1    LC  Forwarding Engine          1.006       1.006           No
     1    LC  SFP                        1.004       1.004           No
     2    LC  Power Manager              4.008       4.008           No
     2    LC  IO                         1.016       1.016           No
     2    LC  Forwarding Engine          1.006       1.006           No
     2    LC  FE Bridge(1)              186.006      186.006           No
     2    LC  FE Bridge(2)              186.006      186.006           No
     2    LC  Linksec Engine(1)          2.006       2.006           No
     2    LC  Linksec Engine(2)          2.006       2.006           No
     2    LC  Linksec Engine(3)          2.006       2.006           No
     2    LC  Linksec Engine(4)          2.006       2.006           No
     2    LC  Linksec Engine(5)          2.006       2.006           No
     2    LC  Linksec Engine(6)          2.006       2.006           No
     2    LC  Linksec Engine(7)          2.006       2.006           No
     2    LC  Linksec Engine(8)          2.006       2.006           No
     5   SUP  Power Manager              3.009       3.009           No
     5   SUP  IO                         3.028       3.028           No
     5   SUP  Inband                     1.008       1.008           No
     5   SUP  Local Bus CPLD             3.000       3.000           No
     5   SUP  CMP CPLD                   6.000       6.000           No
     1  Xbar  Power Manager              2.010       2.010           No
     2  Xbar  Power Manager              2.010       2.010           No
     3  Xbar  Power Manager              2.010       2.010           No
     1   FAN  Fan Controller (1)         0.007       0.007           No
     1   FAN  Fan Controller (2)         0.007       0.007           No
     2   FAN  Fan Controller (1)         0.007       0.007           No
     2   FAN  Fan Controller (2)         0.007       0.007           No
     3   FAN  Fan Controller (1)         0.007       0.007           No
     3   FAN  Fan Controller (2)        0.007       0.007           No
     4   FAN  Fan Controller (1)         0.007       0.007           No
     4   FAN  Fan Controller (2)         0.007       0.007           No
The EPLD is OK to support FEX. Could you double check if the SFP is supported, in case you use copper connection.
http://www.cisco.com/en/US/partner/docs/switches/datacenter/hw/nexus7000/installation/guide/n7k_connect_specs.html#wp1044250
Also, please be aware that 5.1.2 is a deffer code. It would be better if you could upgrade to 5.1.3 in your production enviroment.
http://www.cisco.com/cisco/software/advisory.html?imageGuId=0E71CAA06C8E4F37F7DBA85136033F14D66356B3&i=rs
if the issue is the same after upgrade, please open a TAC case.
Cheers, Jack
FYI - I finally got confirmation from Cisco that the 2224 isn't supported on this release even though the N2K document says it is.  The 2224 support comes with the Delhi release, only the 2248 is supported right now.
