Unified Computing System Knowledge Base
Knowledge Base Articles
UCS PE supports uploading B-Series and C-Series server firmware bundles.  Because of the large file sizes of the firmware bundles, UCS PE only supports uploading of stripped-down versions with only the firmware metadata (not the actual firmware binar...
ericwill by Cisco Employee
  • 54406 Views
  • 29 comments
  • 38 Helpful votes
A Field Guide covering advanced network configurations for Cisco Compute Hyperconverged with Nutanix systems. This guide covers network configurations with disjoint layer 2 networks north of the Cisco UCS domain, i.e. two distinct physically separat...
beveritt by Cisco Employee
  • 2316 Views
  • 0 comments
  • 4 Helpful votes
****UPDATE July 2021   The HUU images launched with our C-Series M6 Rack Servers are now compatible with the following USB creator toolsets:   Tool name Tool link  Supported on Windows Supported on Linux Supported on Mac  UEFI mode UEFI s...
UPDATE 10/25/22: The IMC Emulator will be decommissioned at the end of this week. There has not been any active development with the utility in several years, and as such we will be removing this page. The Cisco IMC Emulator allows users to familiar...
The following Cisco UCS Platform Emulators are available for download from Cisco: Current Cisco UCS Platform Emulators CONFIGURATION IMPORT NOTE:  Importing configuration backups (All, System, or Logical) taken from the UCS Platform Emulator (UCSPE)...
  • 542677 Views
  • 127 comments
  • 136 Helpful votes
UCS Communities Login ID: robbeckTwitter handle (optional): TechBeck03Have you read the Official Rules of the Contest and do you accept the terms and conditions     Yes  [X ]    No  [   ]Are you a Cisco employee                                       ...
robbeck by Cisco Employee
  • 76607 Views
  • 102 comments
  • 49 Helpful votes
Step by Step Process to Find UCS Drivers and Install on UCS-C series(Rack Servers) How to find Compatible Drivers: Use Cisco UCS HCL Tool to Find the Drivers: https://ucshcltool.cloudapps.cisco.com/public/   Select the options in the drop down as p...
Top Contributors
