Hello on UCSC-C220-M7S, how do you get serial number of installed network adapter? both inventory-all and show network-adapter detail dont have serial number on it I can't them find on cimc gui either Thanks
Hello,I’m preparing to deploy a Windows Server 2025 Hyper-V cluster on a Cisco UCS X9508 chassis, and I’d like to understand the best practices for this setup.In particular, I’d appreciate advice on the following points:Recommended firmware versions ...
Hello FreindsPls post me the download Link for the BIOS Upgrade file & the CIMC Firmware Upgrade file for UCS C220 M3 AND UCS C240 M4 S2Thanks a lotIbrahim
Cisco UCSM running B200 M5'sToday I was performing infrastructure and server firmware upgrades. My upgrade was going from 4.3(2f) to 4.3(3c). The infrastructure upgrade was successful. After creating my new host firmware package and modifying my u...
Hello Freindsas per the below CPU Specs , 12 Cores=24vCPU , the Question is does the 24vCPU shared between VMs ,aka VM1 Consumes 16vCPU & VM2 Also Consumes 16vCPU ?thanks
Hello FreindsI have only 1 CPU in my UCS C240 M4 S2 Lab server, i need to add another CPU-2 , what do i need to order ? aka part -number for CPU , FAN ,SCREW , tolls , etcThanks a lot
Anyone using Proxmox virtual environment on Cisco UCS currently? I have a customer seriously want to purchase UCS C/X Series and the same time their server team is seriously considering moving from VMware to Proxmox...But what is the compatibility be...
I recently got a C240 M5 server for lab use. When powered on, fans are running at full speed, around 12k RPM nonstop. Unit was new in box, so no previous config or dust issues. I've tried setting the fan profile to acoustic and low power with no chan...
Hello FreindsI'm not able to launch the Cisco vKVM Console on UCS C240 M4 S2 to map the ISO , i m using the below JAVA Runtime versionPlease Advise jre-6u14-windows-i586errors below java logs<?xml version="1.0" encoding="UTF-8"?><jnlp codebase="https...
Hey friends, found various threads about disabling Secure Boot on Secure Appliances based on UCS C-Series. But it is not clear to me if anyone ever managed to do so. Got a FMC 4600 based on UCS C220 M5 at hand. Would be one hell of a waste throwing t...
[FSM:FAILED]: downloading Image Dom.xml from local(FSM:sam:dme:FirmwareDownloaderDownload).Remote-Invocation-Error: Unable to open downloaded Image# ID: 1308401Fabric Interconnect, Cause: fsm-failedCode: F009690Severity: Critical (all levels) I am ge...
Is it possible to get an update on fix status? The suggested workaround is not really workable for production as it would leave us without KVM access to the blade.
Hello FreindsI got (4x64GB) RAM for Cisco UCS C240 M4, DDR4 2400MHz PC4-19200 ECC LRDIMM Now the server has only CPU-1 12 Cores , where to install this RAMs?is it on A1,B1,C1,D1 DIMMs Slots in order to be recognized by Serverpls advisethanks a lot
I am in the process of configuring a Cisco UCS C245 M6 server with an NVIDIA A100 80GB 250W GPU in a VMware ESXi 8.0 U3 environment. The goal is to enable GPU passthrough to a virtual machine running a Linux-based OS (such as RHEL or OEL). However, a...
