difficulties with SuSE 11.2 boot-from-SAN
reltest01
Hello!
I'm having a challenging time getting SuSE 11.2 to SAN-boot and am wondering what others have done to get this going.
I am aware of this page:
http://www.cisco.com/en/US/docs/unified_computing/ucs/os-install-guides/linux/BSERIES-LINUX_chapter_010.html#t_sanbootinstallation
Specifically:
Step 6   At the boot prompt on the first installation screen, enter the kernel modifier command.
boot: linux pci=nomsi mpath
But I kept getting:
Error No active partition
Reboot and Select proper Boot device
or Insert Boot Media in selected Boot device and press a key.
I am using an identical setup (Boot Policy same, same array, etc) as my other B200s that have successfully installed ESXi and bare metal RedHat, so I'm wondering what I might be missing to get my SuSE Server going?
All tips are appreciated!  Thank you!!
kg6itcraig
On 6200 series FI's after updating from 2.0x to 2.1x RPM based linux systems stoped booting for me. Debian systems have not had the issue. This is with M3 blades.
My fix was local drives since only one server was effected and I had drives around.
What code are you running?
Craig
My UCS Blog http://realworlducs.com
Ah that's interesting, thanks Craig.  I'm running 2.1(2a).
This is on a B200 M2 though I do have some M3s available.
Unfortunately, local boot is not an option... we need to be 100% SAN.
It is always best to be 100% SAN.
2.1(2f) will run a little better but will not fix the issue.
I would try downgrading the code on the blade to 2.0(x) and seeing if that fixes the issues.
Thanks Craig.
Rolling back to 2.0(x) won't be an option for us.  I could probably justify our moving up to 2.1(2f) but it seems that didn't actually resolve the problem for you.
It's unfortunate you and I are running into this issue... I'm hoping someone else has found a Cisco fix or perhaps an ISO of the necessary SuSE drivers to get SuSE boot-from-SAN working.
Thanks again!
