11-09-2014 03:54 AM - edited 03-21-2019 08:26 AM
Was curious if we could specify the line a key on the 500DS should use. The reason for this is that theres different PBX's connected to this phone.
Example:
Key1: fnc=sd;sub=ext@$PROXY (Use Line 1 of 525G2)
Key2: fnc=sd;sub=ext@$PROXY2 (Use Line 5 of 525G2)
11-09-2014 07:51 PM
You probably want to move this to the SMB area.
11-10-2014 09:32 AM
Thanks. Its been moved :)
11-18-2014 12:28 PM
Use
vid=# specifies the extension the sidecar key is associated with. By default, it is Ext 1
Rate useful responses. It will help others to found solutions. Or mark thread as answered ...
