10-03-2013 08:01 AM - edited 03-21-2019 07:49 AM
Hi!
I need to CISCO SPA502G terminals are permanently blocked, and:
.- To talk or click on the headset, the terminal asks a code (personal to each user).
.- When entering the code the phone is put to the extension assigned to that code.
The terminals are recorded against and setup Asterisk reaches them via tftpboot on a xml.
Thank you very much
Solved! Go to Solution.
10-03-2013 02:33 PM
It seems you are calling for feature named
Following documents may help you as well:
Alberto Montilla's description here: SPA525g SPA9xx Extension Mobility & provisioning
But note System abend. Don't use EMS & MUID macro as part of Profile_Rul URL (SPA50x, fw 7.5.3). It apply to fw 7.5.4 as well. The bug in question has been patched in 7.5.5.
10-03-2013 02:33 PM
10-04-2013 02:46 AM
thanks for your reply.
I will study the information provided
