502G phone lock
Papa_Foxtrot
Hi!
I need to CISCO SPA502G terminals are permanently blocked, and:
.- To talk or click on the headset, the terminal asks a code (personal to each user).
.- When entering the code the phone is put to the extension assigned to that code.
The terminals are recorded against and setup Asterisk reaches them via tftpboot on a xml.
Thank you very much
Dan Lukes
It seems you are calling for feature named
Following documents may help you as well:
Alberto Montilla's description here: SPA525g SPA9xx Extension Mobility & provisioning
But note System abend. Don't use EMS & MUID macro as part of Profile_Rul URL (SPA50x, fw 7.5.3). It apply to fw 7.5.4 as well. The bug in question has been patched in 7.5.5.
Dan Lukes
thanks for your reply.
I will study the information provided
