Hi all, If my UC560 is configured using CCA and then I want to make changes using CLI( assuming that CCA is not available on laptop) , is that supported? Regards Sriram
Is there any reason that these phones will not work on BE6K 10.5? I just cant seemt to get them to register! Download XML.Dfault.cnf.xml is stuck in the display. Does this file come from CUCM or the Router? I know on the old UC500 they downloa...
Outgoing to cell - I can hear caller, they can't hear me. incoming from cell - OK Outgoing and incoming to/from UK landline OK Outgoing to PBX- I can hear caller, they can't hear me. Incoming from PBX- not tested What could be the possible cause of t...
UC320W listening 5064 port on WAN and any desirous can use your device as SIP proxy! | SIP Device | User Agent | Fingerprint |-----------------------------------------------------------| X.X.X.X:5064 | Cisco/UC320W-2.3.3(4) | disabl...
I have a spa112 phone adapter and linksys EA4500 router and i am having problems with no audio on phone calls. The person at the other end can hear me but i can't hear them. I am curently using freephoneline.ca. I had it working for two years until i...
Hello, I am trying to update two SPA504G phones because hopefully it will make the MWI light go off after I have listened to the voicemails. The red MWI alert stays on, so does the envelope indicator on the screen along with the intermittent dial to...
I have setup my new SPA112 with a EdgeRouter. Router config: Forward port 5060-5061 to SPA112 Forward port 16000-17000 to SPA112(also tried 10000-35000) SPA112 Config: NAT: EXT IP, Keep Alive (my ISP doesn't use a STUN server, tried another STUN se...
I have a spa525G2 using SIP at a remote location which needs to register to a TFTP server over the Internet.The remote locaiton does not have a TFTP server or option 66 or 150 in DHCP, so I want to either hard code the IP of the TFTP server in the 52...
Hello, I need to configure inbound calls from SIP provider to UC520 and then to CUCM 8.6.2 The calls do no go through, when a trace is performed the SIP Trunk Provider says UC520 replying with "500 internal server error" in response to inbound cal...
Hello I am configuring a UC320 and performed a factory reset, hold button 10 sec, won't restart now, Gui errors out, after login screen system shows ' intializing new config' it gets to 20% and errors out " error parsing XML data from input XML is mi...
WHAT?There is a known incompatiblity with Adobe Flash Player 11 and UC320W Configuration Utility running on firmware earlier than 2.1.2. This incompatibility prevents the UC320W Configuration Utility from loading. If a user tries to launch a browse...
Hi everybody I've just bought a second hand UC540. I've restored the factory defaults and it's now configured for my SIP provider and is working great in my small office with 4 7975 phones. I'm a developer and I would like to use TAPI/CTI to make a c...
I have an unlocked SPA2102 running the latest firmware (5.2.12). The date/time just get reset back to 1/1/2003 (I think) after a couple of days.It is hooked up to a UPS and there is no black out. It has been doing this for over a month. I tried the o...
Hello my bad English soryy sound from the handset as follows: https://drive.google.com/a/djalper.net/file/d/0BxYvJ8BVZ0ACZUMyaEMtSXg1MG8/view?usp=sharing I updated but not improvement
Hello everyone, I have a Cisco UC520 with one FXO analog PSTN line and a SIP Trunk. I am using custom Music on Hold which had been working great. I am not sure what happened but now anyone connected to the PSTN line will hear beeps rather than actual...
