Hi There Hope you can help. I have the above system for our small business. We are in the building industry and we find a lot of clients hang up before leaving a message as they want a response there and then. Often I just miss the call or it diverts...
3PCC
(4) -
3rd Party Call Control
(5) -
ATAs
(33) -
ATAs and Gateways and Accessories
(1,990) -
ATAs Gateways and Accessories
(2) -
Buying Recommendation
(6) -
Cisco Cafe
(5) -
Cisco IP Phone 6800 Series with Multiplatform Firmware
(23) -
Cisco IP Phone 7800 Series
(223) -
Cisco IP Phone 8800 Series
(55) -
Cisco Small Business SPA300 Series IP Phones
(339) -
Cisco Small Business SPA500 Series IP Phones
(2,793) -
Cisco Software
(3) -
Cisco.com Idea Center
(1) -
Community Feedback Forum
(6) -
Community Ideas
(3) -
CP7800
(1) -
CUCM
(1) -
DECT
(1) -
(34) -
IP Telephony
(7) -
MPP
(2) -
Online Tools and Resources
(1) -
Other IP Telephony
(1) -
Other IP Telephony and Phone
(28) -
Other Unified Communications
(1) -
Small Business Support Service
(1) -
Small Business Voice and Conferencing
(18) -
SPA500
(1) -
Voice Gateways
(1) -
Voice Systems
(11,486) -
Wired
(1)
- « Previous « Previous
- Next » Next »
My call display suddenly stopped working, just showing "Incoming call".I'm trying to upgrade the firmware current 1.0.2 (006) to see if it resolve the issue.I downloaded the latest firm ware no problem.I logged into the "Phone Adapter Configuration U...
We have a UC540 with the FXS analog inputs configured as user phones. We call a call blast group setup for pilot # 8000.When the door stations go off hook the line rings but does not hit the 8000 blast group.Where is do you program the number to dia...
My customer was shipped a BE6000S as part of the Demo Loan Program.There is no configuration on the 2900 router, should there be?Thanks,ww3
I have a SPA122 and I've read from a user on another forum that he set up a dial plan such that it will use a different provider depending on the number used.I have two VoIP services, one for local calls and another for international calls (voip.ms) ...
Hello,i have a problem, im getting Request failed on my SPA508G / FW 7.5.4 / test.xml<?xml version="1.0" encoding="UTF-8"?><CiscoIPPhoneDirectory><Title>Book</Title><Prompt>Test Book</Prompt><DirectoryEntry><Name>Test</Name><Telephone>9999</Telephone...
Please tell me how to transfer a call to someone's voicemail on this phone model.Thank you.
Dear All, My customer has installed an BE6K , but now the BE6K system status LED is Amber blinking. From the UCS C220 document , the amber blinking LED means the server is in a critical fault state, for example, boot failed, fatal CPU and/or bus err...
Hi,I have a SPA112 ATA that I use for my voip service. The ATA is behind my router (D_LINK DIR-868L) so port forwarding is enabled for 69UDP, 5060-5080TCP+UDP, 9000-14000TCP+UDP and 50000-60000TCP+UDP.For some reason, I can dial out and the audio wor...
I was hesitant to bump an old thread, so here it is for reference:https://supportforums.cisco.com/discussion/11735651/help-spa8000s-getting-hackedHow did that issue resolve, if at all? No firmware update has been released since that time, and I don't...
Hi Howard/Dan et alRelated to the same discussion under the “SPA 3102 - 'PSTN to VOIP' Call not establishing on CLI/CID enabled Telephone Line” couple of days/weeks ago. That is the reason why I am addressing to these 2 gentleman here. If anyone else...
I am trying to upload a new background image via the file management interface in CCA to a UC500 series system... it will show the valid file structure and as well the images but when I try to upload one it gives me an error opening TFTP and says Loo...
All 3 of our phones, Model # Cisco IP Phone SPA 525G are not working. We can get a dial tone but we cannot hear callers and they cannot hear us. We share an office with another doctor and they use the same modem, router, etc. but with a different ph...
I am using SPA514g (7.5.2) phones with Asterisk (Elastix) and am having a problem keeping the "Message Waiting" setting set to "Yes".When this option is set to "yes" voice mail's light the MWI light as expected.The problem is when I make a change in ...
Hi Guys!!We have just purchased a new BE6K server for my company and we are planning to install and deploy it in the next week.We already have a BE5K version 6 .I want to do a fresh install of the BE6K using the old DLUs of the BE5K.I am not sure ab...
