Hello !Whether there is some way for reboot SPA112 via network using script language? For example remote phone can be reboot by "http://<Phone_IP_Address>/admin/reboot".Kind Regards, Wojciech Krakowski
I purchased a CISCO SPA232D and I just connected.I want to know how to configure the device so that the PSTN line is passing, that can continue to use the analog phone without problems. I noticed that when the device is switched off, the line is pass...
Hi There, We have an IP Phone model SPA525G and we've been having trouble getting the "call waiting" feature to work. I've gone to user preferences on the phone and toggled the call waiting feature on and off multiple times but we still cannot get a ...
Hello everybody, I have an issue I haven't be able to solve for days. Our customer has a Cisco SPA525G2 phone connected with 3cx. The phone works fine but when we try to setup the line Keys 2, 3, 4, and 5 to point to other extensions, the last 3 butt...
Hello.Can anybody help how to configure MoH on SPA122.I have CISCO 2951 with CME 10.5 with config moh enable-g711 "flash:/music-on-hold.au" multicast moh 239.1.1.40 port 2000 route 10.40.3.240Music play on 7931,7961 phone wthen put on hold from this ...
hi guys,i have run debug on the phone system to find out why the cfwdall feature isn't working, but i can't figure out why. this is the log from debug voice ccapi, i looked all the lines carefully and it looks like it matched every single dial peer w...
I've recently moved away from SIP trunks feeding our UC520 over to PRI. Unit originally did not have a PRI card which was installed and additional configs were added to get it working.One problem we're having is the CFwdAll feature to external numbe...
Hi I configured Lync 2013 and UC to work together. As one of the last steps I wanted to configure SNR on Cisco so that when desk phone is ringing also Lync client rings as well. It was straight forward configuration on UC - on Lync everything is defa...
Hi,I'm having problem with SPA122 ATA. When customer hear the fax tone, and press start button, it takes about 15 seconds before start sending !!!. Is there any parameter I can adjust for faster speed.
Is there a way to send a DN out a specific port on a UC540?Here is the problem:We have a UC540 with 4 POTS lines plugged into the voice ports. We are wanting certain DN's to go out specific ports so dailed callers see a certain number on there caller...
HelloOur UC320W has developed a problem about a week ago. I've run FXO Impedance Matching on the affected FXO ports and adjusted the values accordingly, but it's had no effect. To the best of my knowledge, nothing has changed at all on the lines them...
Hi anyone know if is posible to connect this: Site A: UC320Various Cisco SPA phonesSwichRouter Site B: SPA525g2Router -- Can i use the option of VPN in SPA525 to login into a vpn to the UC320?
Hello I have a SPA3102 and I use it with a SPA112 to send a pstn line to a remote location.When i receive call everything works fine but when i dial out from the spa112 i cannot make any calls.I see on my SPA3102 that in the status page, Last Called ...
Hi support,I just found a bug in the latest phone firmware 7.5.6.Platform:Linux Debian WheezyAsterisk 11.7FreePBX 2.11Affected Cisco phone model: SPA504G and SPA514G(I only tested these two models)The issue is when there is an incoming call with anon...
I am using an SPA504G with a SIP provider. They support group call pickup and this has been configured through their web based GUI along with the BLF group. I have been told the feature code for group pickup is *8 (they run an Asterisk server). This ...
