HelloI'm installing a Cisco SPA 525G2 -5Line ip phone but i'm unable to successfully register the phone. When all configuration are saved .. I still get the following error message :++++++Registration State: Failed - Not Reachable++++++Can someone...
Hello,I bought a Cisco 303 phone from ebay. It came in, and I went to set it up. However, soon after I realized I was unable to activate it because the previous owner of this phone set a password on it. We have contacted the previous owner and have r...
Has anyone experienced the call park light showing up incorrectly. I've seen this on a few UC500s when the call park light is on, but there is no current person on the line. It seems like the call light or the call park status won't clear.In this c...
I'm sure my terminology is wrong, sorry. So we have a uc540 with 2 pots lines. Sometimes someone will want to transfer a call to their cell phone or do a teleconference.If a teleconference is started between two pots lines and one internal phone, and...
We are small business with two users and have no need to use a passcode when retrieving voicemails from the phone. Can we simply press the email button on the phone to retrieve voicemails without entering a passcode ?
We are small business with two users and have no need to use a passcode when retrieving voicemails from the phone. Can we simply press the email button on the phone to retrieve voicemails with entering a passcode ?
I'm using FreePBX with Grandstream phones. I have FreePBX configured to allow Listen *222ext#, Whisper *223ext#, and Barge *224ext#.All I have to do is dial *222 plus the extension and I can Listen in on a call. Works great. My problem is we just pu...
I have a SPA514G When a call is missed on extension 2 for example, in the call history it is indicated that the intended extension the call was sent to by [E2]<number of missed call> for extension 2 for example. The problem is, when I press "Dial" to...
I have a customer with multiple numbers registered on each phone. line 1-4 is the number for that phone, and 4-8 are multiple registrations on each person in the company. Lines 4-8 are the main numbers for 4 different businesses and they need to be...
Hello everyone!I am writing here hoping to find a solution to a problem that is making me lose a lot of time.I have a phone (SPA504) configured with three extensions (100,200,300) of an Asterisk PBX.I need to configure the CallForwardAllNumbers for a...
I have a Cisco SPA514g, I want to secure the web interface with a password. When I change the password and it reboots the phone comes up fine. On certain functions in now asks for the user password for example on redial. Is there a way to disable the...
I've just set up Live Record for a UC540 customer for the first time, but with some issues. I'm working with Cisco support, but having a very difficult time getting timely answers. Do any of you know:1. The recorded message, a very small test mess...
Product: SPA122Firmware: 1.3.5UXAttached device: Brother J430W Connected PBX: 3CXProblem Description:I have successfully set SPA122 up with Brother J430W to send fax over 3CX PBX. However, whenever I finished faxing, SPA122's FXS port stays off-hook...
I am having issues with a cisco SPA8000 and Avaya Office IP 500. I am using the SPA to provide dial tone to the switch. Everything is working except releasing (Dropping) a conference call. The lines participating in the conference call are getting st...
