Resolved! UC520 - will this support 7960G phones
I am trying to get clarification if the Cisco 7960G phone which are currently end of life are supported with the UC500 series.
I'm from a small non-profit which has SPA504G phones that we are planning on implementing in a hosted VOIP service. One vendor that we like a lot claims that their solution, which uses Broadsoft switches, doesn't support the SPA504G phones. Instead, ...
I am trying to access my UC540 (latest software) to (re)record a new AA prompt.If I dial the main number, then 397/398/399, I get "Invalid ID".How can I admin prompts remotely (i.e. to record a temporary weather closure message)?
We have been running callconnector with no problems for the past 1 year, as of last week the database goes down pretty much hourly. The only change we made around the same time as this started was we changed admin passwords on all our servers / route...
This phone adapter was working well until the provider when out of business. The new company is trying to interface this phone adapter to work with their system. The previous provider, provided me with the administrative password. This was used to...
Dear Sirs,is there any way with asterisk to notify the SPA500S on unavailable extension in order to switch off the corresponding BLF light?Our operator make wrong transfer because the light still remain green on unavailable or unregistered extension....
Good mornig. The problem i have with my cisco ip iphone spa502g when i finish configuring a switch always reboot. i put an static IP, netmask, gateway. The software version of mi spa502g2 is 7.5.3. i've tried many ways.fo example: the spa502 has the...
Are there any plans to make a version of the TSP driver available that will work in Windows 8? It is a real shame that Microsoft have changed something that has broken this!
Hey Guys, We are getting a High Density Server. I see there is Virtual VCS-C on the 6k with 5 Traversal and 10 NT calls. Now, how do I get the VCS-E enabled from here on. Also i would need Advance Networking/TURN etc. ThanksVR
I am struggling to shorten the Call Waiting Tone length on a Cisco SPA514g, running sofware ver. 7.5.3, hardware ver 1.0.0.I am using the Metaswitch SIP Provisioning server to send a custom config fragment <Call_Waiting_Tone>440@-5;1(.1/.1/1)</Call_W...
how do you assign a softkey template to a 8961 ip phonei have made the softkey template for my 8961 how do I apply it to a phone
Hello, I am looking for some info in regards to defaulting a cisco IP SPA525G, I am trying to provision it on a hosted portal, But when I get to seting the url and telling the phone where to download its files from I get the admin login. I have facto...
Hi,is there a way to change the code the phone sends on dnd ?i have a spa504g that sends 486 (busy) on dnd and provider tells that it should one of 400/401/402/403/603 CALL_REJECTED.Thanks
We are using a Cisco IP Phone SPA525G. We have two of these phones one is in our office and one is in my apartment, both with the same number. The phone was working yesterday Now they are both down, When the phone is working all the buttons on the ph...
Provisioning a new set of spa504G phones. I've always used for spa504G.cfg, the phone finds it. I've always used:<flat-profile><Resync_On_Reset>Yes</Resync_On_Reset><Resync_Periodic>3600</Resync_Periodic><Profile_Rule>tftp://ipaddress/xml/spa$MA.xml<...
