I have a UC320 and a Bogen TPU100B amplfier. Can anyone tell me the type of cable I need to connect the 2 devices? I think the UC320 uses a 3.5 mm jack. The Bogen TPU100 only has a tip and ring connection. Does Cisco sell a cord for this? I have...
Hi i purchased L-UC-PRO-8U --- License wnat to add in UC560-FXO-K9 -- Router need help
Is there a way to reduce the noise in a SPA122?Lycom is has a customer that has a GE Alarm system which is attached that uses 2 loop start lines. I attached the alarm type on email, There is issue is that the Alarm sends the DTMF fast and that our eq...
Hi All,Below is my setup. 4 direct FXO incoming linesReception extension 101 rings whenever receiving any incoming calls.Call will be directed to AUTO_ATTENDANT, after 12 seconds no pick up.AUTO_ATTENDANT DAY TIME (8am – 5.30pm)“Thank you for calling...
When a call comes into Auto Attendant and caller makes selection there is a moment of silence and the call disconnects. This is on a SIP trunk from Vitelity. Any option the caller chooses (transfer by name, transfer by number, etc) the call drops. ...
We have an office with 10 phones and 2 office staff. When somebody calls in the auto attendant answers the phone and are give choices such as press 1 for sales, 2 for service, etc. Each of those options is assigned ahunt group with a voicemail box....
Hi guys, i would like some help trying to figure this out:We have an UC540 system in our office, we also have a broadband internet connection through a local ISP, the UC540 internet connection setup is DHCP, but when i connect the ONT cable into the ...
Setup a 320W on a site, and ran into some phone quality issues. I ran the inpedence test and the settings match. I dont have it handy in front of me right now so I can't read what I do have off(but its the default settings). Is there an actual impede...
Hi,has anyone experienced the same problem as I did: we were using IPsec for remote access for a long time. Without any problem.We've migated to ssl vpn (anyconnect) two months ago. We're experiencing problem with very slow network throughput. I've d...
Hello to all,I am having an issue, maybe you can give some tips whats wrong?Local user dials from his IP phone SPA504 to DPD automated attendant , number. Automated attendant answers a call and invite to enter some numbers. User press numbers on the ...
From the UC500 series EOL announcement:Is there a migration plan for UC300, UC500 and BE 3000 customers? And will my existing SPA phones be included in the plan?Planned for availability on August 1, existing customers on the UC300, UC500, and BE 30...
Hi,i can successfuly connect my spa504g to a kamailio server and get mwi notifications using UDP.when i use tls, i successfuly register in the the server and also subscribe to mwi events.i can make calls and srtp also works.the problem is with kamail...
Hi,I have a uc520.Is it possible to configure buttons on a SPA504g and/or on 500S extension, to dial an external number?Thank you in advance,
Hi! My power reset during upgrade Cisco SPA509G. It's now "S.O.S Phone In Recovery Mode.". I'm download recovery utility and attempt recovery firmware (spa50x-30x-7-5-5-recovery.exe), "Recovery Failed: Cannot find the specified device!". Serial naumb...
I have installed a new UC540 with 5 SPA303 handsets connected through a SG300-20 switch.I have upgraded the UC software to version 8.2 added the associated UK locale pack and everything installed fine.Having run the telephony wizard all appears norma...
