Hi,I am installing BE 6000 right now and I did not see an option to select CMBE 6000 just CUCM 8.6.2.Did I miss something? My OVA references c200 and BE6000Thanks in advance Randall
My test install of the Cisco UC540 w/ SPA525G2 phones (some running remotely over built-in VPN) works pretty well, but...The heaviest user of a remote phone, on occasion, has audio drop-out mostly on the way to him. So the other party is talking, bu...
Hi, I configured Jabber on a UC500 for some iPhone users. Jabber works pretty well, but numbers from the phones' contacts cannot be called directly, since a additional 0 before the actual number is required to dial outside the customers network. Is t...
Hi Folks,I recently swapped two older phones for newer 7965s. Configuration was done through CCA. As long as the phones were not provisioned their GUI looked better then after provisioning them.Basically the font within the soft-key-labels is noticab...
We just installed the UC320W and there is a key feature that we are looking for: we would like to assign dial plan patterns to groups of FXO lines. For example, if you dial 2XX-XXXX your call will go out through the FXO on ports 1 or 2, and if you di...
Hi,I have a PAP2 which is causing dramas, it tries to boot as normal, gets all blue lights as normal for less than a second. It then flashes all with the top light Red, I assume it is rebooting. It keeps going in the same cycle over and over.Is this ...
Guys,One of the advantages of the SPA5xx series of phones is that it supports G722 HD Voice, why is this not being supported as part of the standard config for the UC320, this also translates to the SIP trunk side as well, I would have thought that C...
Hi.I have come across an issue where i require the latest version of firmware for my SPA525G2. The current version it is running is 7.5.2 which has been provisioned through the UC320 and due to this I cant see a way to manually update the firmware fo...
Having discovered the "dialable intercom" feature, I now have quite a few extra buttons on the 500S sidecars.Is there a way to assign speed dials to these buttons? I'm trying to think of a way to increase utility and I have about 20 buttons free, so...
So in the scenario where I'm installing my first UC540, the customer has three different outbound CID's he like to use. One CID is the main business line. The 2nd is a 2nd small business they run out of the same office. The third is a home phone #...
Hi i'm testing the ata 112 and i have some problem during registration to a teles gateway, in the log of the gateway i got the follow message" ignore register (want auth, but no auth found)" i tried to use different configuration but i got always the...
I have a SPA112 2 port phone adapter connected to a TP-LINK TL-WR841N. I can receive calls without problems. I can dial out, yet after 30-40 seconds into the call, I am disconnected. Can someone please help me resolve this issue. Thank you. Mike
I have a SPA525G which I had problems getting pictures from a USB stick to the wallpaper, I did get this resolved with a new USB stick with only the directory /pictures on it as it did not work for me with other files and directories on the stick als...
So here's my problem. I have a new SPA504G that I added to our network, and is having some issues that seem to be netowork related. Our Asterisk phone server is located at 192.168.1.40, and DHCP assiged the phone to 192.168.2.200. Both have the ne...
