With the new 9.0 release the attendant console has dissapeared. Can this just be added separetly on the quote and use one of the 5 application slots?
We have a Cisco UC560 (UC560-FXO-K9) running "Cisco IOS Software, UC500 Software (UC500-ADVIPSERVICESK9-M), Version 15.1(2)T2, RELEASE SOFTWARE (fc1)" The issue is when we have end users connecting with the Cisco VPN Client to this device sometimes ...
Hello,I've read just about every post there is on the issues with the SSL VPN and the SPA525. I hate to bring up another post about this but, I was having stability issues as well with one of my clients. This is a UC520 running the 15.1(2)T2 image....
Hello all. I am setting up the UC320W and I need to be able to forward our calls using our phone provider's call forwarding. Before the UC320, we would dial *72 and the phone number that we wanted all our calls forwarded to. When I try to do it on...
Hi All,When i configure the SPA504G to use the broadsoft personal directory and i do a search for a contact it says no results.I have two users in the personal phone list on the broadsoft portal. Richard and Samuel When i search Richard it displays ...
Hi All,When i do a search in the Broadsoft Enterprise Directory on a SPA504G with firmware 7.5.3 i get strange results. If i do a search voor Mike it will show all Mikes but the phone number that is displayed is different.The result are like this :Mi...
I am looking for dutch user guides for the spa50x series of IP phones. For instance, on the cisco website I can only find a document named 'cisco_spa509g_user_guide.pdf' in English whereas I would like a Dutch version of this to supply to Dutch custo...
I have a UC540 with the PSTN as SIP only; no POTS used. About 10 DIDs registered with the phone company.The goal is to have a bunch of individual DIDs but also group numbers like "sales" and "support" that certain phones can be on.I set it up with t...
Reading through lots and lots of post about this I still can't figure out if there has been a "Simple" solution to this.I have an AA that dumps External calls to Phones via their EXT when typed in, and we want an external call ringing on a phone on b...
Hello. I am new to the UC540 and to SIP. I am trying to route a call to a SIP trunk and I keep getting the SIP/2.0 488 Not Acceptable Here error. I have looked at all cases related to this problem on Google...as well as looking at logs.I have chec...
I'm now on my third power supply for a 3 year old WRP400.First power supply stopped working with a high pitch noise.Second power supply just stopped working.Ambient temperature normal between 20 to 25 °C. Supply voltage around 223V.What is the expect...
Hi all, i have a linksys spa8800 that used to work fine until a week ago, for now the device keeps rebooting with the following message to syslogd:(could it probably a probably some change in the line/phone cabling that was made wrong ?, i am not in ...
Hi, we have a problem with spa112 (firmware Version 1.2.1 (004)).Every 3-4 days this device crashes ....symptoms:1) No dialtone2) IVR not responding3) Web GUI not respondingOnly way to restore functionality - power cycle a devicceWe have tried other ...
So I have a client who's having an issue. The phone is ringing and they pick it up and they see "declined" on the screen. Then they hang up, it rings again, and they can answer the second time. It doesn't happen all the time, but it is happening more...
Hello all.I am working a FreePBX system that implements Cisco SPA 300 series and 500 series solely. I have been trying to find more information regarding programming the line buttons for special features, like call pickup, and the lower 4 programmabl...
