Hello,i have a question regarding the CUCM 8.0.What is the limitation of maximum voice call's at the same time.I need to work this out, to get a full license.Thanks in advance.Jörg
I am working with an SPA8000 that is supplying dialtone to ESTech systems/ESI/IVX pbx phone systems. I have discovered that caller ID information is not being received by what they call their "legacy" or older model pbx's. I have confirmed that calle...
HelloThere are a atas186 who was registered to a CUCM version 6.1,the call manager was migrated to version 8.6 but now the second por when a call is answered immediately when give a fast busy tone, the first port works perfect, and i have changed man...
I am having a hard time trying to find documentation on how to set this up. Does anyone know where I can find the documentation on how to configure this or show me how to configure this.. Thanks!!!
Having issues getting SIP working . I setup using SMART designs, but still have an issue. The network topology is voice routing only. The LAN side of the UC320 is working well for both wireless/LAN 192.168.0.0 and VOIP 10.1.1.0. I have set the WAN po...
Hi Team,on the PC there is an active process that insistently queries the UC540 with a telnet session (not secure)... What is it? An accessory of CCA that controls the type of installation also without opening the program?Meanwhile, the little thing ...
Hi,Are there plans for the BE3K to support handset/jabber call encryption to the local lan?Further to this the oportunity requires about 10 remote handsets / Jabber clients.What's the best way to solve this - via an ASA with UC phone proxy licences? ...
Hello,I have a UC540. I have received reports from users that on occassion messages that are being email out contain no audio.I don't know where to being diagnosing this. I can see voicemail messages being dispatched through our mail server.Allan
Dear Community,which protocol should I use for a successful installation of an 7961 IP Phone?Is a manually upgrade via tftp necessary, or does it updated during startup by the UC540 itself?Has someone experience with this kind of connection which ver...
I have a UC320W with the latest firmware loaded that has been having trouble from day one with a particular line disconnecting properly. At times one line will stay connected indefinitely until it is either unplugged or the phone system reset. Obvi...
I have two units and am having the same issue with both. I did a factory reset on both and when the configuration screen opens the counter goes to 100 and stays there. There is no prompt to login. Used Firefox and IE, any ideas?Bob
Hi!I'm troubleshooting an integration of two (2) SPA525G2 phones with UC320W. One of the things I want to do is upgrade SPA525G2 phones firmware. Currently, these phones are using SW 7.4.8 version and I want to upgrade it to 7.5.2 to see if it helps ...
Yesterday I´ve installed a UC320W with 9x SPA303 and a SF200 switch.The problem is that the phones didn´t get the POE and I was forced to use the transformers.The POE in the SF200 is working because I also have a WAP121-E-K9 plugged in and working.Be...
