Good morning, I'm using a USB wired Mono Jabra Headset Evolve 30 II with my Cisco CP-9971 phone. I don't hear my voice in the headset speaker but others hear me. Is there a way to enable the headset so that I also hear my voice? Thank you, Chuck
I have an SPA122 ATA w/router which has been working fine. I use VOIP.MS to provide telephone access. Recently, I changed my email and password with VOIP.MS which resulted in no dial tone. They indicated that I needed to access the firmware on the SP...
Hello.Been running the Cisco UC560 for the past 9 years now and until today, it's worked flawlessly. Now I've run into the problem with the CUE.I've checked on Cisco's website and they no longer have any updates for the UC560. I was hoping someone he...
Hi, I'm trying to set up my voicemail account, and it has an old employee code or pin so I need to find a way of setting my direct line up. Is there a way of you guys helping me?
Hello. I have a SPA112 setup with my voip pbx. Line 1 is connected to my (very old - late 1980s ITI Caretaker system) alarm system. Line 2 is a normal analog phone. Both lines work correctly (dialing out and receiving calls) when the phone is hooked ...
It's clear that most users of the UC320W are a little frustrated by its shortcomings and even moreso by the fact it's going end-of-life.What are the plans for a replacement around the same price point?
When calling from the Patton M-ATA device, to any number (internal extension or outside number) and capturing the call using Wireshark, I get the error. No problems calling to the Patton device.
Hi,I have an SPA112. I just dug it out of storage and plugged it in. I did a factory reset (pressed reset for 20 seconds). Now when it powers on I get power LED flashing for a while, then solid and network light comes on and flashes. then the pow...
We have used ATA 186 devices with our Call Manager system for use with fax machines and analog phones in a manufacturing environment. I am hopeful that the SPA112 can be used as a lower cost alternative to the older ATAs. I have searched for basic...
I am having hard time finding the firmware that supported for :Serial No: CCQ170801LYPID: SPA122 V02TAN: 74-9318-02 PLEASE HELP
Hello, I've had the SPA504G phones for over 5 years. Yesterday my regular list of extensions was gone and only 770101 is showing on the display. It allows outgoing calls still but no one is able to call in via my regular extension. How do I get my ol...
When I access the web page for the device, I only see Voice, Administration & Status. I cannot configure the device. I've defaulted the device. I'm using admin/admin to log in to the device.
A few users had full voicemail boxes and now the system will not accept any more. Cannot get to cue via gui and after a restart cannot get to it via ssh either
he genson cme installed on 2811 (Cisco IOS Software (C2800NM-SPSERVICESK9-M), Version 12.4(24)T2)analog phones on EM-HDA-8FXS stopped working no dial tone? router#sh invNAME: "2811 chassis", DESCR: "2811 chassis"PID: CISCO2811 , VID: V03 , SN: FHK103...
Hi there, I´m from Sweden and am not the best at technical english so bare with me. We have installed an intercom system at an apartment complex which visitors should be able to call the residents cellphone which they intend to visit. The intercom sy...
