Not sure what is happening on this one. UC520 latest sw pack has decided that the onboard FXS ports will no longer dial out. Dialing inturnal extensions is fine both ways. DID's incoming to those FXS ports also work. Dialing access code 9 for the...
I just installed a UC320W. When I first set it up I didn't have any lines connected or anything. I wanted to make sure I understood how it worked before I deployed it. I was able to get in and setup my personal voicemail.However, now that I have the ...
We've had problems with 7900 series sidecars (and phones with sidecars on them) for some time. Recently this has been worse, and has given me the opportunity to research this across our customer base.What I found:7975 + (2)7916-24: We have 4 of these...
Dear experts,I need help with my UC-560-T1E1. I'm trying to enable Meet-Me Conference. Using CCA --> Telephony --> Voice Features + Enable Multi-party Conferencing+ Mode G711 ( All phone use G711 as well)+ Maximum Multi-party session : 2 (1 for adhoc...
Hello,One of my customer have some Linksys SPA8000 and PAP2T products and when they try to use their analog FXS ports, they get busy tone instead of dial tone in fisrt 3-5 seconds. then it gives dial tone. If they reset products to check if problem ...
HiCan you confirm that i can have 100 users across 5 sites with a UC560 - this looks ok from the datasheets. There must be 2 attendant consoles for operator usage.Therefore I'm ordering the following:1 x SW-UCC-CME=1 x SW-UCC-SERVER 2 x L-SW-UCC-OPER...
Well, after hours of netgear support, we can't get the uc320 system working properly with VLAN's. I'm going to be returning the switch next week and diving into a cisco switch.We currently have a need for 20 ports. We may soon be moving to a new buil...
Hi Guys, The download for the latest SPA5XX Linux SPC tool is broken, the zip file returns unexpected end. Also the eariler version of the SPC tool will not run on linux, I get a segment fault when I exacute it. Appears to be the same problem men...
Is there a way to configure the phones (Cisco SPA509G) so that they talk to each other, like an intercom system?Or configure them to talk to each other, IP to IP?Basically internally we would have 16 Cisco phones, they would connect to a Cisco switch...
I have things hooked up as follows:PBX<==>SPA3102<==>ATA186<==>Analog phoneIP Addresses:SPA3102 - 10.1.1.144ATA186 - 10.1.1.45SPA3102 Config:Firmware 5.2.13(GW002)Line1 is off.Ethernet cable is connected to the Internet portOn the PSTN Line Tab: ...
Plugged the phone into my network, made a factory reset (still had settings of previous owner on it) - then went to setup a Static IP address. Telephone rebooted and now its stuck at the Cisco screen. Tried unplugging/plugging several times, but it...
I need some help with dial plans. We need a 10 digit dial plan as all local call must have the area code. The default that came with the US540 is North American 7 digit dial plan. Thanks
HistoryWe have been using PAP2t and they worked and provisioned well.I create the file on my tftp server and then plug the PAP2T into my network. In 5 minutes it has downloaded its config, upgraded its firmware and is registered. The IVR works afte...
I am new to Cisco small business but not to the Cisco product line.I have a customer with a Main site with 7 employees and 1 remote site with 3 workers. They want a new network upgrade including VoIP. Here is what I am proposing.Main Site:UC560-FXO...
