I've heard that more than one MOH is now supported in CCA, but I don't see this option under Telephony > Voice Features > Music on hold. What's the procedure for this?
The UC560 is running the latest version 8.6 uc500-advipservicesk9-mz.151-4.M4bI cannot get Trnsfr-to-VM to work for these phones. Right now I have a ephone-dn setup as so:ephone-dn 100 number 6... no-reg primary call-forward all 500These phones only...
Just wanted to confirm before purchasing how the UC560 handles PSTN Analog lines. We have 8 analog lines each with a different number.. example 123-456-7899, 123-456-7898, 123-456-7897 etc....If the office wants to use one of the numbers as the "mai...
I have recently upgraded my WRP400 with the latest firmware (2.00.26) and found that the DDNS updating function with dyndns.org is stopped.I made tests with the previous firmwares (2.00.20 and even with the old 1.01.00) and DDNS updating works with t...
Still confused about night service code.Floating Extension 157. SIP DID points to 157. CfwdAll - Blast group for a bunch of phones (during the day). Night service call forward all points to a different blast group (during the night). Night service co...
Another bug to report:On a CiscoIPPhoneExecute POST, if you pass a URL with multiple parameters, only the first parameter is collected. I was forced to bundle all my parameters into one and pull them all out again.Syslog excerpt:Jul 12 22:13:12 172.1...
Seems like noone uses XML on these phones as I have found a number of bugs as follows:1) The Header Refresh MUST have a URL specified. This is optional in the standard2) Sending a Softkey Cancel in a CiscoIPPhoneExecute crashes the phone. request reb...
i am trying to configuredqsic trunk between cme and panasonic pbx.but the controller is down.here is the show command.cme#show controllers e1E1 0/2/0 is down. Applique type is Channelized E1 - balanced Transmitter is sending remote alarm. Receive...
Using newest firmware 1.2.1 , anyone else having this problem ? If i set the jitter level to medium + and try calling out it works fine. If i set No to use jitter and have it set to low, same thing. is this a bug or am i misunderstadning how jitter...
Help, please.I've just deployed a UC560 with SPA502's and 525g's, the 502 are registering fine and getting the correct ip address. The 525's are also getting the correct ip address, however they are not getting any configuration. I've checked and r...
Hi, I wanted if possible to configure BLF for SPA 502G phone. It is configured with SPCP signaling protocol. I cannot change anything in webadmin page and I think that is because I use SPCP so I need to configure it in ephone-dn. Can someone help me ...
Hello there. I ran into an interesting problem. I have this UC520 here that I wanted to update with the 8.6.0 package. So, I let CCA go to town and to the upgrade. However, upon final reboot, nothing was happening. So i got into the serial inter...
Good Day,Hope someone can assist me?I have a UC 520 running software release: uc500-advipservicesk9-mz.151-2.T2, I would like to register a Cisco 3905 IP phone to the UC520 but I understand I need CME 8.8 for this to work. I have searched the whole C...
