HiI just bought SPA122 which come with firmware v 1.2.1(004). I try to upgrade to current version but the 'choose file'button is not functioning. I have try all the solution under the thread of "SPA122 firmware upgrade "choose file" grayed out" but n...
Hi, the only way to block some number in SPA112 is in "Selective Call Forward Settings" under "Cfwd Selx Caller:" adding the number and leaving blank "Cfwd Selx Dest:"?If so, I can't block more than 8 number!Cisco, can you solve this problem? Thanks ...
I have a brand new SPA112 and configured just enough to connect to my router and on to my VoIP provider - in genral all is working. I cna make calls and receive calls. However there is one problem. I have a Panasonic DECT phone and when I go off hook...
Good day!Linksys PAP2T device. The voice disappears after 5 minutes of conversation. The call dump shows that Linksys sends an invite at the 300th second - can this be connected? How to disable the send of an Invite request during a call?
Hello, I'm trying to resolve a problem with a remote workers SPA525G2 phone that disconnects due to poor rural wireless Internet connectivity. This specific user has been using this setup for at least 6 years, the only difference has been the rural w...
I Have 5 spa 525g2 phones and they have a preset ”custom”firmeware fore Telavox, factory reset does not work, it only returns to custom firmware after 5min, i have tried to uppgrade firmeware but stil coes back to ”custom” firme ware, i need to load ...
The situation I am dealing with is a small office of appx (10) SPA504G phones. When the phones use the paging options between office the phones do not auto answer. The information about the office - Running an IP-PBX with a stated Asterisk based sy...
We have Cisco SPA303 on the latest firmware 7.6.2SR5 and our security scanner is picking up vulnerabilities in the SPA303's. I need to Edit the crossdomain.xml file, ensuring:No 'site-control' tags have the "permitted-cross-domain-policies" set to "a...
Hello. I have an issue with phones (All types) randomly unregistering on a UC520 through out the day. I have same firmware running on multiple systems so I dont believe it is an IOS or firmware version problem. I am guessing it is a command in the co...
Hi Team, We are running Skype for Business 2015 on prem and I have 2 analog phones which I need connected to the SfB server.Would either the SPA-122 or SPA2102 work to connect to my SfB server?Has anyone got any documentation how I could go about thi...
I always have my ASUS AC87U Router connected to a VPN to avoid having to connect all of my devices individually to a VPN. However, whenever my router is connected to a VPN my Cisco SPA112 doesn't work in that there is no dialling tone on my phone tha...
HI,
When press the star key four times: ****, the spa112 said "Enter the password...". (We lent the device to a supplier)
Press and hold the button for 10 seconds to restore the factory default settings not disable password!
thank for you help!
Marth...
SPA 8000 firmware 6.1.12SR1
Ports 3-8 seem to be sending an IP address on the SPA's own LAN (192.168.101.X) in their SIP registration messages. Ports 1-2 send the IP of the device itself. Any way to get the device to use its own actual IP (WAN st...
Hi, I have gotten a Cisco UC520 and it is Username and Password Procted. How do I reset it? I have tried the Pause and Break Key and that did not work. What else should I do. And yes, I have tried the basic passwords ( cisco/cisco, Admin/password...
