I have a UC560 that I just installed. I have Voicemail notification set up to email the voicemail to an Exchange server. I have noticed that Live Record messages do not get sent to the Exchange server. Is this a bug or is this by design? I see th...
Are there plans to support the 9900 series phones with the Business Edition 3000 solution? The 9951 is actually very similar to the 8961 phone, which is already supported on BE3000, except that the 9951 supports a video camera attached to the phone. ...
Hi All,I have a uc540 in my network. It was working perfectly then suddenly stopped working.In a bid to solve the issue, I resetted the UC540 to factory default. I the tried configuring it with the help of CCA. The prob is that the SPA504and 7911 con...
Hi Everyone,One of our client having UC520 has issue with Voicemail.When i dial internally with ip phone it works fine but externally AA fails.Pls check the debug:Jun 13 08:22:23.613: //-1/BC9155439722/CCAPI/cc_api_display_ie_subfields:cc_api_call_se...
In CCA 3.2(1), UC560 is running software pack 8.2.If we go into the backgrounds or Ringotones to add new ones, the screens come up blank with a message "The embedded TFTP server can not start or is unreachable." There is no 3rd party tftp server run...
Hello! I am installing a new UC540, that was configured entirely in CCA. I've installed Office Manager, and manually pointed it to the UC540 (It would not discover it). I've entered my username, password, and enable password, but receive the message ...
Hi,In SPA122 with fw version 1.1.0 (11) tftp client is not operative when DMZ is Enabled, provisioning not working. When DMZ is active, the request to SERVER TFTP to complete successfully but the response sent directly to the private IP (DMZ). With f...
We need group paging to a single zone for immediate deployment. One way to do this is to use any phone to dial an extension which connects to a paging system through the FXS port on the ISR 2901. Any advice?*Partner Request on 8.6.3*
I am looking into setting up Disctinctive Ring on a UC560. The problem is , I need to set it up on a call that is forwarded to a hunt group from a NOA. Any help would be appreciated.
Hi All,I couldn't find anywhere to set up DHCP on BE 3K GUI interface ? Seems like BE3K doesn't support DHCP function. If so , does that mean we have to manually assign static ip addresses on each phone ( think about 100 users ) if there is no ...
Hello, I can't get connectivity between my computer and UC560. My UC560 with the IP 192.168.10.1 is connected to a poe switch where the ip phones are connected.The phones are in the 192.68.10.x net. On the other hand, the computers are connected to a...
Hi,i upgraded the UC520 with 8.6 software pack and when it came to restoring the backup it failed and my UC is kind of stuck it is not able to call outside just works internally.i tried to resotre the backup again but fails. not sure what to do.Need ...
We are experiencing an issue on transfers where no progress tones are heard by the caller. If A and B are on a call and A transfers the call to C, then B doesn't hear any ringing whilst waiting for C to answer. Note that A hears ringing when calling ...
