Hello friends,how I can change the region pack for Central America ?regards
hi guys, i did not found a guide yet for the uc540 about connecting a sip trunk to the system.. so im asking it here.Am i suposed to connect the network cable from my sip trunk router into any fastethernet port?if so, how do i tell the uc540 wich por...
dear all i have UC520-32U-8FXO-K9 currently installed in my office with 15 IP phones distributed on internal users , i have five PSTN lines connected to this system , all those lines grouped in one line so any outside person wants to call us he can d...
Hello!I have a UC320 with 6 SPA509G phones connected to it. Every few days the phones continously reboot until the UC320 is reset. I have upgraded the UC320 to the latest firmware and tried different cables/switches.Any thoughts on what other steps...
HiI got a WRP400 running.The Line Status on the site Voice->Status is indicating "Registered". Thus SIP-Account-Settings should be fine.At the WRP400 the green LED Line 1 is lite. There is no dial tone when I un-hook the phone. I tried several phones...
Hi there,We are using a UC540 with 4x ISDN BRI lines. In the past we also used a seperate analog line for our fax. Recently we have conected our fax server to one of the analog ports on the UC540. Since then we have problems with incoming faxes. Unti...
Hello,Need your help, friends. First time I'm dealing with cisco SMB solutions. Client wants to buy couple of SPA504 and 3905 cisco phones for his office. They don't have any Cisco Call Agent on their site, so they will buy third-party IP-PBX system ...
Hi,is it possible to set a fixed volume through provisioning/web GUI that overrides user set speaker volume for the case in which a Paging call is auto-answered? I haven't found a setting for this. If there is none, please consider this a feature req...
So we have 3 managers who share one assistant. So I'm getting ready to set each manager in a group with the same assistant so that the one manager's phone and the shared assistant phone will ring if any of the manager's phones ring. But they'd really...
Hi FolksThe Literature states that the Be3K can drive up to 9 remote sites. What constitutes a remote site ?One remote phone at someone's home ?Two remote phones working in a remote officeTen remote phones working of a network in a remote office ?I
Hi I have a Linksys PAP2T-NA which was setup and worked fine using the sipgate service. This week I was in mid-call and the line went dead. I rebooted the adaptor at which point I lost the dial tone on the phone plugged in to the adaptor. I have the...
We have a 10 user remote site with a leased point-to-point connection (10Mb with approximately 10ms round-trip time for pings). The line is used mostly for RDP (terminal server) traffic and it's usually somewhere between 10% and 25% utilization (alth...
I will raise the age old question so as to keep the information fresh. Are able to or are we closer to being able to connect a remote phone to the UC320 by any means?
Hello,I attempted to upgrade a UC520 to 8.2.0 of the software pack using CCA and the upgrade failed at the restore configuration step. I'm now left with a UC520 that will not allow me to log into CUE. Whenever I attempt to start a session from the co...
Hi.Is It possible to setup a second wan Interface for redundancy on the uc540w? If It's possible , will licensing restrictions also be an Issue ?
