Any way to upload additional ringers to the 525G2 phones either on a per phone basis or system wide? The choices provided with the exception of the "office" ringer seem rather corny and not professional.
Hye All,I have a 7942g phone. it's IP configuration is static and it has to register on a UC540 that has a capacity of 40 ephones.Right now, 14 phones are registered on this equipment but when i wish to add any other phone, it mentions registration r...
Hi All,I have another nagging question and hoping you good folks can assist.I have a SPA504G phone and have configured SNR on an ephone dn that appears on button 2.The SNR feature itself works fine, however when attempting to use the "Mobility" softk...
Is it possible to have either a softkey or replace a line button with an Extension Mobility logon button?Our customer has UC560 (CME 8.1) with SPA504G handsets.Thanks in advanceMatty
I am having a problem with my IP Phone 525g which is getting worse and I really need some help to figure out: its only on my device or a know issue.Here is the problem I have:Early on, I've realized if I set my Bluetooth configuration to both(handsfr...
Hi All,I was wondering if anyone could shed some light on this problem.I have 80+ SPA942 phones running on a 3CX v10.0 SoftPBX system and have had no problems so far.I was tasked with supplying some new phone but keeping withing the Linksys/ Cisco f...
Hello!We have a UC540 (UC540W-BRI-K9). On this we have configured following:Incoming call -> Hunt group pilot 511 -> extensions 203, 204. If nobody picks up the call, it will be forwarded to hunt group pilot 512. After there also no one pick up the c...
Hi,I am using UC540. I have 3 blast groups created which has three different DID numbers assigned to it. How can I set up a callerID for each of these 3 blast groups. For example, if a user from a prticular blast group dials out his outgoing number a...
I think I already know the answers to these (No) but I wanted to confirm with the community. The phone system is a uc560 with spa phones.1) Receptionist has a sidecar with all the phone extensions laid across the buttons in monitor mode. When a pho...
Looking for help with yahoo smtp settings. I've followed the admin guide and have it setup correctly but no emails. I've had this problem before with other devices and a yahoo account for email notifs but I am probing you guys and gals for a solution...
The Scenario -My Customer has 2 sites with Less than 50 user each.-They currently 3 digit dial between the two locations with their existing phone system (NEC) and the use of a PTP circuit. -Site 1's extension range is 100-199 & 300-399, Site 2's ex...
Hello,I recently upgraded from the 8.1 firware to the 8.2 firware on my UC540. The upgrade went smoothly and there were seemingly no issues until the next day I attempted to access my webvpn and found it no longer worked. I am using the anyconnect-...
