Voice Systems and Accessories - Small Business
Upgrade your communication system with our Voice Systems and Accessories, perfect for small businesses.
Hallo Guys,   is it possible to sync the call status from Cisco IP Phone with Skype for Business. Why I'm asking. When you are calling with the IP Phone your Skype status is green as available he didn't change to call as busy. How it's possible chang...
HelloI am trying to set up some SPA8800 VGWs to have calls come in on the FXO ports make a SIP call to a primary VGW and if that VGW  is not available then hunt, or make another SIP call to a second VGW. I have the first SIP call working in Dial Plan...
FW Version 1.4.1SR1 (002)   VOIP.ms technical support has recommended contacting CISCO as my SPA122 continually fails and denies incoming calls from ringing on the (2) Phone 1 and Phone 2 ports. The only remedy that seems to work is restoring the bac...
Hi, I've tried to configure without success a SPA 122 in order to convert VOIP to PSTN for a fax first. I've found several tutorials and followed every steps but it didn't work. I've realized that when i was filling the quick setup page and then subm...
LucD by Level 1
  • 1910 Views
  • 6 replies
