Hi all,I installed the card "VIC2-2BRI-NT/TE =" in the UC560I restarted the UC560.It is not recognised.There is a special procedure to make it recognize?Thank'sThierry
Is there really no way of having a user know if another user they are calling is on the phone rather then ignoring the call, with call-waiting enabled?
Hello,I want to configue an HuntGroup that ends at a GD Mailbox.How can I then assign this mail box to the people in this groups phone so that they can see if there is a message??So on the phone it would be Button 1: Their EXT ...
I have a customer that had some employees leave and they wanted me to swap out their old employees phones for some of their lower end models. I set up all the configs in CCA and have gone back and checked to make sure it is all also changed in CUE a...
Team,Customer has a uc520 installed with the basic AA in place ("Welcome to the automated attendant, If you know your party's extension you may dial it now") Problem is I have workers who want to somehow break in and get to their voicemail which in m...
Hi therei'm tring to set rings onto a Spa501 via Sip Alert-info. the phone already had last firmware 7.4.8.ai'm using several sintax to pass the ring nameSIPAddHeader(Alert-Info:n=Office)SIPAddHeader(Alert-Info:n=1)SIPAddHeader(Alert-Info:Office) wit...
Team,I have been trying to get a uc300 system to work across a vpn (using Linksys rvs4000's) to no avail. My next attempt I want to take 2 800 series ISR's and actually try to trunk to the uc300 on one side and vpn from the wan...This box has been FU...
I am trying to configure the two front-desk phones in our office so that call-waiting is not active on them. Right now I have them setup in a call-blast group. Our main incoming DID is configured to go straight to the group - that is working and bo...
Hi to everybody. I ve no changes in config since two months but now i ve a problem. Calls out Ok, but when someone calls in the autoattendant answer well, but after one press the key and makes one of the three selection available, the call ring for a...
I have now run into this problem twice when setting up additional phones on UC540 systems with CCA 3.1 that were initially configured using CCA 3.0.Yesterday I was at a customer site replacing two SPA525 loaner phones with new SPA508 phones. I delete...
Hi,I've hit an issue where CCA3.1 is being used to manage a UC560 previously setup with the earlier release.It looks like 3.1 now configures Unity to use RTP-NTE rather than SIP-NOTIFY. It changes this setting when a change is made to something like ...
Hello,I have purchased stock Linksys SPA2102 ATA adapter with no operator configuration. By default all settings are for US phone devices.Which settings I should change that my SPA adapter would be perfectly configured to operate together with PSTN d...
