Hi, I have an XML file with the below codes and hosted on a public server. I have tried to link the XML on to the Cisco SPA 504G but it shows failure to retrieve directory. Can someone please help . <CiscoIPPhoneDirectory> <Title>Cisco Copora...
we bought 20 spa112 ip phone adapters and cannot log into them to change the ip address! help!
Anyone ever experience a ring voltage drop on the SPA122? First ring measured has 72 volts and there after drops to low 60's. The firmware is 1.3.5 (004p)
Hello everyone, I am using spa3000. And I am trying to route the incoming calls to IVR using Freepbx. Line 1 is registered but the pstn line is not registered. And the phone connected to the spa3000 is ringing itself. All the configuration that I hav...
Patrick,Thank you for posting the 3.1.20 firmware.This firmware, while reducing echo, introduced a DTMF bug where # is expanded in dial plans as 2 3.Would it be possible for you to also post the 3.1.18 firmware for those affected by the bug and wh...
Hi there everyone, I'm sure that this is an easy fix but I cant seem to figure it out and i cant find any answers on the web. I have an UC540W-FXO-K9, a SPA525G2 with the SPA500DS Expansion Module attached I am connecting to the UC via CCA Ver 3.2....
Hola, mi nombre es Martin Marques, soy de Argentina.Tengo problemas al transferir llamados con un cisco SPA-112 conectado a una PBX PANASONIC KX-TDE100.En el cisco tengo configurados dos internos SIP (210 y 211). Cuando realizo una llamada al interno...
Hello, We have call park feature configured on "*4", here is how it works now: having a call established I press 'xfer'(initiating transfer) -> '*4' -> <listening to call parked announcement -> 'xfer' (to complete transfer). The question is - can I...
Hello everyone, I'm attempting to connect my SPA525G2 to Asterisk 13.12.1 (on FreePBX 13.0.192.18) via TLS as well as setup SRTP but I'm stumped on how to load the TLS/SRTP certificates/keys on the SPA525G2? Referring to the screenshot, it appears t...
I configured a Cisco SPA 122 and I am able to get a line registered and it shows up from the SIP trunk provider, but because the provider requires a prefix to be added to the dialplan I always get a busy signal calling out. I tried the following (*...
I have an XML provisioning server for SPA devices and I would like to make it available through HTTPS. I read the document at https://supportforums.cisco.com/docs/DOC-9852which states that I need to send my CSR to my Cisco sales rep who will forward ...
Hello, I have recently bought CISCO SPA504G, I am new to setting up ip phones so need your guidance in this. Q1: I am using sipgate basic for my ip phone, I need to enable MOH on the IP Phone, I just want the default CISCO Music to play but it re...
My hope is that in documenting events here in some detail, I may somehow find a solution. For many years, I ran a Billion 7401VGP partly as an ATA solution for phone calls. It was reasonably solid apart from the occasional echo but it has been retire...
Hi I have a Cisco SPA 112 that is connected to an analogue bell. The SPA 112 and bell are setup using STUN as an extension on a 3CX system. My issue is that there is a delay before it starts ringing, the bell is about 4-5 seconds later than the ph...
I purchased the SPA2102 a couple of days ago, and was able to go into the configuration and set up my VOIP. The phone is working now, but I need to go back into config to set up some other options. When I enter http://192.168.0.1 into my browser, i...
