Does anybody have a CISCO IP phone running over either Skype or Vonage or any VoIP company that offers great rates? I need some people to give me their expertise. Thank you.
I have a UC520 with a SPA525G phone registered with SCCP and I am asked to add a500S module which is SIP. Do I have to recreate the525G IP phone and use SIP as its signaling protocol?
I'm using the SPA962, and having an issue with numerical button presses, IE: If I call a bank or any service that requries me to type any sort of numerical code, the receiving side gets codes like (5555 22222 33 - if I had only dialed 523). Not q...
Buen DiaMe pueden confirmar si los 8 puertos FXS se pueden configurar con codec G.729, esto es por que tengo un proveedor de servicios de VOIP que me va a entregar lineas IP y queremos optimizar el ancho de banda a utilizar de cada puerto.SaludosOlga...
Hi All, a few days ago I posted about having call quality issues with one way audio problems with a UC520. The circuit is clean and checked multiple times and im almost think that maybe I should do a code upgrade.I'm used to upgrading IOS on routers ...
How do I get my 7936 to work properly on my UC520? You can make and receive calls but you cannot use the keypad during calls. Works fine on a UC540 but not on my UC520. Example: If you dial the voicemail service, the key pad cannot be used to enter y...
I'm seeing intermittent out-of-memory (H737202d1)errors and reboots being reported in the system log from an SPA-2102:Oct 20 03:39:19 phb4 System started: ip@192.168.1.6, reboot reason:H737202d1Oct 20 03:39:19 phb4 System started: ip@192.168.1.6, reb...
We enabled the broadworks feature sync and have noticed strange behavior. The feature syncs up DND, CF All and CF No Answer. The problem seems to be that the cisco phone CFNA timer on the phone is in seconds and the Broadsoft timer is in number ...
HI,I would like to know if is possible to configure the SPA962 -line keys- to control PSTN lines connected to a SPA400. I have 4 PSTN lines connected to a SPA400 and I would like to control this from my SPA962 as follow:SPA962 Line Key Number1 ...
Is the Application Event Handles part of the Cisco XML App Developer Guide applicable to the SPA500-series? I'm specifically looking into closing an app by pressing a specific softkey (<SoftKeyItem><Name>Exit</Name><URL>App:Close:1:2:app/id</URL><Pos...
I need 29 numbers to block. I have applied a rule in a profile that rejects 15 numbers on the dial-peer, my problem is how to add the other 14 numbers to reject, or if there is another way to do this??? Thanks for your attentionP.D. This is the conf...
How do I configure star67 ( outgoing caller id block) on a UC520 . This is different from the internal caller id block.So dialed number is lets say a prefix of 11 and the number 8084445511 translates to *6718088084445511 and is forwarded to the pstn...
Does Cisco Small Business TAC support using UC560 integration with Exchange?I have found a way to supposedly do it, but I want to be sure it is supported once customer moves to Smartnet.Thank you
Hi everybody,I have a customer who wants to forward all calls to an organism which will take messages when his company closes.So I would like to create a script which initialize a telnet connection to the UC and do CLI for changing a voice translatio...
