In SPA525G can not insert the ñ in WPAPSK wi-fi.sorry for my English.
Hi all,I understand the gui has been removed, that fine :S.I want to setup voicemail notification but what is the best way of doing this (simple notification only)? Am I ok doing this on the CUE Cli – but is this supported etc?I also want to be able ...
Hi,I am using SPA 504G IP Phone with CFWD Notify Serv set to yes for receiving notification from server for forwarded my calls. SPA sends SUBSCRIBE with event "missed-call-summary".I have read that only Sylantro and SPA 9000 supports this feature. Is...
Hi Guys,I'm connecting IP Phones CP-524 to a UC520 with software pack 8.0.4. and the phones can not register, the phones shows in the screen the following information:Downloding XMLDefaultAny of you had expirience this problem?
HiI have uc-560 with spa-502G and spa-504G (cue 7.1.3)I am unnable to read the voicemail message on the phoneThe phone have the voicemessage icon and red led indicate that there is message in the voice mailwhen I press the voicemail buton(199) i hav...
I'm using B-ACD and when the call rings the extension (from the members list) and the agent is still on that extension it beeps in their ear. Is there a way to turn this off? I was able to turn off the hunt group beep by 'no call-waiting beep' on t...
I just installed my first UC 560 system on two PRI lines from Telepacific. My client wants to block outbound Caller ID. They would like those they call to get "Unknown Caller" or similar when they call out. I am using CCA 2.2.5 to configure the UC 56...
I have a problem using the XML resync method with the Cisco 525G. The issue is that when the phone executes my resync xml file it expands $PSN to 'SPA525G' and not '525G'.Even stranger, when I issue the same resync command via URL (or add it to the...
How do you define the soft keys in the XML file? I found an example but can't seem to get it to work. The keys never change.
Hi all,In the Cisco App Developer notes it says cookies are supported but I'm unable to get my SPA504G (7.4.6) to return the cookie I set, hence it ends up creating a new session for every request. Are cookies supported on the SPA500-series when usin...
right now some phones ring 8 times and some just ring for ever. the extention is assigned to a phone and the mail box is activated.
Does anybody have a CISCO IP phone running over either Skype or Vonage or any VoIP company that offers great rates? I need some people to give me their expertise. Thank you.
I have a UC520 with a SPA525G phone registered with SCCP and I am asked to add a500S module which is SIP. Do I have to recreate the525G IP phone and use SIP as its signaling protocol?
I'm using the SPA962, and having an issue with numerical button presses, IE: If I call a bank or any service that requries me to type any sort of numerical code, the receiving side gets codes like (5555 22222 33 - if I had only dialed 523). Not q...
Buen DiaMe pueden confirmar si los 8 puertos FXS se pueden configurar con codec G.729, esto es por que tengo un proveedor de servicios de VOIP que me va a entregar lineas IP y queremos optimizar el ancho de banda a utilizar de cada puerto.SaludosOlga...
