when i tried to apply a ephone-templete under ephone CLI it prompt for following errorcan't open file system:\its\SEP001E.F728.283D.cnf.xml for write.Because of that my ephone didnt get the templete settings. i dont know where to start?Thanks
Hi,when i configure sip trunk to the provider.I get a problem to call the Pilot Number of VM (here is 500) and AA (501), calls are failed.Here is the configuration i make.voice service voip allow-connections h323 to h323 allow-connections h323 to sip...
Dear Sirs,I found some problem with SPA525G, firmware 7.4.6Backlight turn on, timer is 30 sec. Everything is fine, backlight works 30 sec., after it turn off. When press any key - it turns on.But sometimes (after few hours of unuse, for example) it d...
UC5408.0.4 using CCA 2.2.5During initial wizard, I specified Access Code to be "8".After install is complete, I can't make calls out with either 8 nor 9.I went into Dial Plan, Outgoing and it shows my default access code as 8, however the Outgoing Nu...
I have configured voicemail to email notifications - all working perfectly, however the notification emails are being time-stamped incorrectly (time stamp refers to an hour earlier than actual time). I immediately thought the CUE clock was out and th...
Phones on a UC540 are getting IP addresses from a Windwos server connected to vlan1 (data vlan) and not from the local UC540 vlan 100 voice vlan. In looking at the dhcp debug, when the phone is reset, it is only looking on vlan 1 for an IP address. T...
Hi team, How can we access internal extensions from PSTN w/o purchasing DID from SP?In CME I think we can do it by just issuing the "No direct-inward-dial" under the dial peer... So when the user dials a certain number from PSTN he gets a second dial...
I'm at a loss on what this could be. I have a new phone that shows a single registered extension for all four lines. Another SPA504G doesn't have this problem and only shows the one extension for the one line. To this point I've tried reflashing th...
What are the options for using IP Overhead Paging? I'm looking at PagePro IPTM, SIP Based Paging Server, Model VIP-201.Running 8.0.4 and CCA 2.2.5I know the CCA can't configure a SIP device, but could I set up via CLI?
We have a customer who is on a UC540, using 504G and the 500S exp module with the latest phone firmware (from 8.0.4 pack) at thier front desk.The two users are both experiencing what they describe as the speakerphone randomly coming on unexpectedly.T...
I have setup my SPA942 to have three different lines. All working fine. However, when making outbound calls, always the number of line 1 is displayed for the receiver. How to set up the SPA942 to display the correct number for each line?
hi,we have a VoIP infrastructure vendor to another where there are related iphone cisco 7905, 7906, 7960, but we would go to uc560-bri-k9 and reused the existing iPhone, I can not tell if they are compatible with the platform in question.Thank you in...
can i make separated line in inbound and outbound ,that man that I can make DID in my in bound for any line and I can choose which line I can go out with it .This configuration I want it with elastix (asterisk)
Can anyone tell me actual differences between the UC520 and UC560 with regards to memory and processor/performance. I have a customer who is running a UC520 with multiple services and high bandwidth internet. The only have 16 phones but they run th...
Trying to understand how this command works,Syntax DescriptionorigThis dial peer is permitted to originate calls. Thus, the access server can accept incoming calls from the dial peer.termThis dial peer is permitted to terminate calls. Thus, the acces...
