Is there a way to cause the phone to use a different outgoing line other than their phone extension line? Specifically a shared line.Thanks for a responseStephanie
Hello,I have had my first UC500 Project finished. All is working fine. Only incoming calls from the same City will be displayed with the Costumers number.Will say a call comes in like 6912341234 it will be shown as 0695675670 (wich is the destination...
Hi everyoneI have installed localization packet for Portuguese (Brazil) and all ip phones are working fine(This is the packet installed CME-locale-pt_BR-Portuguese-7.0.1.1.tar)However IP Phones 521G and 524G after the installation still showing the...
Call to DID at a no answer state, voicemail answers " There is no mailbox associated with this extension. "uc500-advipservicesk9-mz.124-11.XW6.binUC520 with 12.4I have the DID in the primary E.164 number, deleted and re-created, restarted... Users c...
There are 3 computer at my office and one of this is a server. Our modem does not give ip addresses automatically to comps so we configured it manually. It was giving automatically before, after this ip problem we could not use our voip phones. I che...
I have a new installation of UC540 and a SIP trunk to Telco. Everything looks good exept for the 7936 phonesdont seem to send DTMF commands from the keypad. Other phones such as 7940 and 7941 work fine with DTMF.Any ideas where to look ?7936 DTMF cod...
I have incoming calls setup on FXO ports to ring the operator. After 15 secs, the extension is setup to go to AA. After 15 seconds it goes to a fast busy. I also tried to have incoming calls go to a blast group for 15 secs then AA but the result i...
Does TimeCardView and CallConnectors come with UC520 bundle? Or is there any extra charges for these applications, if yes what are the charges.Can some one please show steps to configure and install Extension Mobility on IP phones.Thank youNaazish
So I have a client who we just upgraded to 8.0.2 . This is UC520 is just an 8 user license. However when I do a show ver on the device I see:14 User Licenses10 FastEthernet interfaces2 terminal lines1 Virtual Private Network (VPN) Module8 Voice FXO...
Hi all,I have a customer that is confused and upset about the fact that there are all these greetings and what use are they if everytime you want to use them you have to go in and activate them. So I'm looking for some kind of help in making it happe...
I have a customer that is utilizing the following:UC520 with PRI and 30 7960 phonesThey are also using the salesforce.com connector for call logging. This works fine until the customer installs two other connectors from Salesforce (office and outloo...
I have ASDSL connection to the WAN port of an SPA3102.The SPA3102 keeps loosing the connection, sometimes for hours, sometimes for minutes.If a conversation is establish, it will not hold more than 960 seconds.If I reboot it using /admin/reboot it wo...
