Easy to create a dial string with pauses in it using the web interface pdir.htm Can't see a way to put anything other than 0-9 * and # when programming directory entries at the set. Googled to no avail. Thanks!
Hi Guys, We have just got some SPA502G phones to set up usually we used to receive calls and we just to have some sort of short dial where we dialled a code (300) and it would dial a mobile number. It wasn't another extension either. I have been ...
when I try to upgrade with the cca I get this error. "cannot retrieve CUE version information"dont know what to do nextim using cca 1.9.1can anybody help ?
hello guys how are you i have a question am trying to configure two cisco ip phone 504g with 3cx i have created extention in 3cx web console whend i log in using the ip address for the phone i put the extension and ip address for the web server for...
Hi , i have a voip network consisting only on linksys spa9xx sometimes there is no audio (RTP) while sip signalling is working.I have disabled every form of QoS on both switches and phones trying to figure out what triggers the problem, but i haven't...
I have one 504 and a 303 both of which have admin passwords on them so I can't factory reset them. I know I need to run a wireshark trace route and edit the admin password in the file that it's looking for. But how do I do this? If anyone knows ho...
In my company I’ve service's center that receive contacts using PBX with (DTMF) analog normal lines. so I need to use a special corded telephone for this center, with caller ID display and number remains on this display screen after getting the call ...
I'm developing an app to use CSTA with UC520. I can register lines for receiving CTI messages except for shared lines. Then I get the following error :<operation>invalidDeviceID</operation>Any helpTxFilip
i have a lot of this devices. and i wan't to give it to my customers but i want to know this:Is there a way that when the factory reset the device, do not lose the field where the profile rule goes? That is, do not lose the link, for example my prov ...
Colleagues, good afternoon I called three weeks in support cisco, but there is no answer and no calls back. That's decided to write here, I hope to help answer. There is such a cisco 2951's with software c2951-universalk9-mz.SPA.154-3.M2.bin on it i...
Summary: $CCERT variable can be used in neither Profile_Rule nor Report_Rule. Description: Once 2048b certificates has been introduced, the value of CCERT variable has been changed to "Installed (2048 bits)". Unfortunately, content of expanded varia...
Hello, My SPA 504G cann't register with domain specified in sip proxy. Though domain is resolvable from same LAN. If I put ip address instead of domain, it registeres successfully. If I put different domain, it registeres successfully as well. DNS SR...
Issue: As long as the configured name of proxy resolve to IP address in the form of <any>.<any>.<any>.255 (regardless of the class of IP address) the phone doesn't complete boot. Message "Checking DNS" remain shown on display. The extension affected ...
Hi, I need to recover a .cfg configuration file regarding a CISCO IP PHONE 303, in order to "transfer" it toward an other CISCO phone which has the 7912 IP PHONE model ; All this transfer will be through a tftp server. These are my two questions : 1)...
Hello support community, I'm having an issue with calls coming into our environment sending a loud and long incoming call beep to the handset. This is not something that occurs when the call is coming internally. Is there something obvious that I am...
