Voice Systems and Accessories - Small Business
Upgrade your communication system with our Voice Systems and Accessories, perfect for small businesses.
Hi everyone, I need help with getting a UC520 to upgrade to 48 users. I have licensed successfully, however the 48 user license wont go active. I have copied the show license commands below.  The license installs, however the command from configurati...
My SPA8800 picks up calls but randomly decides to disconnect the call immediately after.  This is an intermittent condition and in most cases, if you call back it will hold the call after an off-hook event.  The errors sent to my syslog are below but...
Hi there, I'm just looking at this product. What i'd like to know is can this be set up with 4 analogue lines for inbound calls (because customer is still in contract with provider so can't fully migrate to SIP) and then use SIP provider for 4 outbo...
Hi, I got a customer with around 1000+ Cisco SPA 502 phones on our Broadsoft Broadworks Platform R21SP1. The phones are on 7.6.2. Phones are configured with Admin Password. I am trying to configure the Broadsoft Directory and configured the below i...
Hello, Could you please describe the correct way to obtain up-to-date CA certificate list for the Cisco ATA and SPA series? We provide complex software solution for VoIP, including provisioning server for our customer devices. We need this CA certif...
For our Cisco IP Communicator soft phones (used with UC500 series routers) we are seeing the following error messages in the status messages log each time the CIPC software is started:"Error Updating Locale""CTL update failed"The errors do not appear...
Dear Sirs, I’m trying to connect a CP-7937 conference Station in a UC 560. In this UC I’ve got several phones working correctly. When I configure the mac address previously in the UC, the unit gets IP, it loads the regional configuration, and after ...
