Hi, I have a spa232d and I have two VoIP phones. However when registering them, they both get the same IP. How do I hand each phone it's own IP, so that I can assign them each an own phone number. I'm using SPA-302D phones.
Hi, I have a 4 ports router and all ports are used. One of them is connected to SPA122 blue port. I want to use the yellow (Ethernet) port as a 5th LAN switch port of the router and connect a printer to it. I set the ATA to bridge mode. The problem...
Hello, My name is Dhaniels, I'm internet & Telephone Service Provider, And i made this because i'm having some problems with the provisioning on the Cisco Spa2102 ( I have a lot of this devices something like 300 Units), So, i don't know how to disab...
Dear all, I have extra 20 SPA509G phones which previously provisioned by VoIP hosted provider and then changed to another. They have pushed firmware 7.6.1 to all phones al so they disabled web login info and activated admin password.for factory rese...
Hello, I am trying to configure a UC560 to automatically call forward all calls to an outside number only on off business hours. The main DN is the pilot of a hunt group. Can this be done? Could you please point me in the right direction? Thanks!
UC540 - can't get smtp working to Office365 for voicemail Migrated to Office365 and using smtp.office365.com for the external smtp server, port 587, correct credentials and getting unknown smtp host. I can get a telnet client, and powershell to both...
Hello, i have an UC560 with one auto-attendant created via CCA using script "aa_sbcs_v03.aef". May i create another auto-attendant for another company/DID number using the same "aa_sbcs_v03.aef" script?, original AAA is not overwritten? Thank you.
UC540W New Customer Need to be able to reset password to access phone system.
Hello All, As the IT guy at my workplace, I've been given the task of updating some of the numbers and names on our UC560 telephony system with SPA504G phones. However, when trying to connect to the PC/EXP port on the UC560, all the documentation I c...
Hello everybody, actually we had to put in service our Cisco UC520, 30 users working. The system works fine, about 1 month to be in service, but people is requesting more and more. Lately some supervisors are requesting call reports, Basic ACD functi...
My company recently purchased the modules for the SPA508G telephones. We also have expansion modules for the SPA525G phones. The screens for the 525 modules are always lit up. The screens for the 508 modules are never lit except when the phone is in ...
Hello, I use he Cisco IP Phone 303 for our call center with Vocalcom and it's work good. but this week we baught a SPA 504G and it's not work.. it's ok in the brekeke and ok in the List of Station in Vocalcom but when the soft want to transmitt the c...
The release notes show that firmware versions 1.33+ are only compatiblewith devices that have serial numbers starting with CCQ17 or CCQ18. Can an SPA122 device with a serial number that starts with CCQ16update to the newer versions? e.g. version 1.35...
I have a really crappy internet connection. The connection drops out intermittently. Problem is - when the connection drops, my Cisco SPA508G de-registers and no longer accepts phone calls. All calls then get diverted to message bank which is a prett...
