When i install the Call Connect Client on a microsoft terminal server i only can assign one user for all terminal sessionsIs there anyone who got this working? or a workaround?
How do you get to the GDM mailbox messages when you set yourself up with PINless login?(assuming of course that you have the rights to that mailbox)
Hi,Is it possible to create template for the softkeys on the 921 and 962 phone´s? Like on the UC520 there´s like a ephone-template configuration, does the SPA solution have the same possibility??Is it possible to localize the 921 phone? I can only fi...
We have recently implemented the mobility feature and LiveRecord on our executive phones, we added the following lines to each users ephone-dn:mobilitysnr 9240xxxxxxx delay 3 timeout 12 cfwd-noan 400I created an ephone-template as follows:ephone-temp...
I am setting up a SPA9000 with and SPA400 for our analog phone lines. The 9000 is not recognizing the 400. What is the default IP for the SPA400? I have gone through all the documentation I can find. Using the wizard does not seem to find the 400...
Hi,I do have an inquiry on the provisioning of WRP400. This is how we configure SPA9x2 phones, just wondering if we can use the same on the WRP400. SPA9x2 phones will first go to our rework bench, the bench has a server with the generic config. We us...
Does, this feature allow you to do for each extension you have in the system? This is similar to find-me n follow-me feature, right?
Dear Tech,How do you guys setup the email notification working? I want to be able to setup the voicemail that will go directly to users' inbox, but I don't want to setup additional IMAP server. I have enabled the notification message setting, and I ...
Hi There,I'm wondering if anyone else has experienced any similar symptoms to the ones that we have on two of our systems. To keep it as short and concise as possible:Whenever we reload (9 out of 10 times - we counted!) from CLI or CCA they always re...
I defined a voice port and dial peer for an fxs port that has an analog phone set plugged into it. The analog phone can call the ip phones but not the other way. What should my config look like for this to work? ThanksPaul
Client has an SBS server and not after putting in a UC500 can't access the remote site.UC500 has XO T1 line.No DHCP on uc500. SBS is handling that.When thru cca and configured NATt for ports 80, 443, 4125, 3389 to 192.168.16.2 IP address of the serv...
I'm looking for information on how to provision the Linsys RT31P2 telephone adapter. It is not mentioned in the spa_provisioning_guide.pdf but it's webpages (and the naming of the parameters) look very similar to the WRT54GS, is the spa_provisioning_...
Hello,Is it possible to set the IPBX (SPA9000) and phone sets (SPA941) so that we accept INBAND PCM for incoming DTMF, and do SIP INFO for outgoing DTMF?Thank you
Just to let others know after it took me a while to get this going. Cisco have forgotten to make English localisation files available for anything other than US English so no UK English, Canadian English etc. The good nes is that you can use previos ...
HI Guys,I have a brand new cisco 2811 router with 8 POE switch for Cisco IP phones. I am after a CCA type java application that I can run to configure the call manager express on this cisco 2811. Can anybody guide me how I can get that or how I can c...
