Hello. CIsco spa122 not working "beep". Can you help me to correctly configure SPA122? I need the test mode worked "beep", without a set of numbers
Looking to Disable the Detect fax function and turn the SPA 112 into a Dial tone generator only of a fixed number/Extention. Our current setup resembles to following INTERNET \/ FreePBX \/ SPA112 (@ extention 666) \/ Another ATA Box (herein referre...
Hello everyone, We have SPA112 in our compagny and it works perfectly. 2 days ago we had "no dialtone" issue and I had to fix this ( usually a simple reboot for ATA and all is fine ) But this time figured out that the registration failed every 30 se...
Hello All, Please i need assistance in designing a solution for the below; I will be using 7821 phones and want to know whether if i use a 2911 router I will be able to do the below and this solution should be capable of allowing inter-branch comm...
When I go to "Administration" tab there are only options for changing web either 80 or 443. No options on left for firmware or anywhere else in the GUI. PLEASE HELP ASAP!!! Scott Parks
I am attempting to attach two Cisco ATA 186s back to back using a router between them. Both have static IPs. I am running 3.02.04(090202A) on both. Are there parameters in the ATAs that I can set so I do not have to have a Call Manager in the circ...
This is a Cisco UC520 that is being migrated from a PRI to a SIP trunk. We can get outbound calls working just fine but anything inbound gives the caller a fast busy. The ISP says our PBX is responding with an "Error 500'. I have tried everything w...
Hi! I am running a SPA504G with 500S Console on Sipgate Team. I would like to configure buttons to automatically initiate a call transfer to a specific number. The dial code would be *384# fnc=sd;ext=*384# Unfortunately if I configure the button in t...
We have several phones. They have firmware 7.4.6 when we factory default the phones they correctly pull spa504G.xml from the TFTP server then they pull the spaPHONEMAC.xml from the tftp server and it seems like everything is correct. But the phone ...
Dear All We have one CISCO SPA3102 and one Cisco PAP2T adapter available at two of our branch offices. Both branches are connected over LAN. We have to configure FXS ports on both branch offices to work as extensions over IP. Kindly let me know if th...
Dear All, I need your help in setting up SPA3102 with CUCM so SPA3102 can be used to make calls from IP phones (registered with CUCM) to PSTN numbers. I was struggling to make it work for many days but still not finding the clue where i am going wron...
Dear Support Community,I have a number of SPA303 IP Phones deployed in a LAN on one site communicating with a SIP server in another site over a VPN and these phones will keep rebooting themselves with the Reboot Reason: Backup IP.Does anybody have a ...
Hi! I have been playing around with my setup for a while now, finally have everything working the way i want to.. except... i found out today that when i am out of office i divert my call to my mobile number. Now the call will actually ring throu...
SPA122 Router/ATA Voip provider changed the phone number, and the Cisco unit now has no dial tone, my analog phone still has power to it provided by the ATA. what was omited, changed so the dial tone quit?
Hey Cisco Community, I work for a small nonprofit organization that uses a UC520 to provide phone service for our various sites (we had a main site, and 3 satellite sites each with an SR520 that connected back over a VPN to the main UC520). We recen...
