BE6K applications didn't come pre-installed on the server
cesekhile
     Hello forum members.How do I handle installation when BE6000 does not come pre-installed on the server?
I'm working on a BE6K, the server came as an RMA after a faulty C220 M3 server was replaced. I have installed the ESXi and created datastores. Since BE6K was not pre-installed, I cannot find the OVA files or deploy OVA template. How do I proceed from here? How do i get the OVA template? Do I create VMs after deplying the OBA? When can i use the CUCM DVD that shipped with bundle?
Jaime Valencia
OVAs are on downloads at cisco.com, you deploy the VM using the OVA, then install the product, This is no different from any other VM deployment/install on ESXi.
If you have install media, just use if for the install.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Thanks guys.
Andrew Hickman
To add to Jaime's response, you might also find this BE6000 Software Load Summary of use.
This is a listing of software that we currently ship with BE6000 servers (we'll also be posting these under BE6000 release notes shortly).
Andy
