ā02-18-2013 07:44 AM - edited ā03-21-2019 06:59 AM
I'm implementing a new IPBX Cisco UC560 withe Unity Express 8.6.3. All is working fine except the voicemail. I configured it from Cisco Configuration Assistant but I have the error message "The recording is too short, record a longer one" when someone wants to leave a message. I read a lot and tried lot of configuration but I can't fix the issue.
The Auto Attendant is working well and I can call the extension 399 which provide the voicemail. May be I need to configure a loopback instead of a vlan interface ?
Can someone help me please ?
The configuration of the router is described below :
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
sip
interface GigabitEthernet0/0
description $FW_OUTSIDE$
ip address dhcp client-id GigabitEthernet0/0
ip access-group 105 in
ip nat outside
ip inspect SDM_LOW out
ip virtual-reassembly in
load-interval 30
shutdown
duplex auto
speed auto
interface Integrated-Service-Engine0/0
description Interface used to manage integrated application modulecue is initialized with default IMAP group
ip unnumbered Vlan102
service-module ip address 10.10.102.253 255.255.255.0
service-module ip default-gateway 10.10.102.1
interface GigabitEthernet0/1/0
switchport mode trunk
switchport voice vlan 102
no ip address
macro description cisco-switch
interface GigabitEthernet0/1/1
no ip address
macro description cisco-switch | cisco-switch | cisco-switch | cisco-switch
interface GigabitEthernet0/1/2
no ip address
macro description cisco-desktop | cisco-desktop | cisco-desktop | cisco-desktop
spanning-tree portfast
interface GigabitEthernet0/1/3
description Interface used to communicate with integrated service module
switchport access vlan 102
no ip address
interface Serial0/2/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn sending-complete
trunk-group ALL_T1E1
no cdp enable
interface Vlan1
description $FW_INSIDE$
ip address 10.10.1.253 255.255.255.0
ip nat inside
interface Vlan90
no ip address
interface Vlan102
ip address 10.10.102.1 255.255.255.0
ip nat inside
interface Vlan200
ip address 10.10.200.254 255.255.255.0
ip nat outside
ip route 0.0.0.0 0.0.0.0 10.10.1.254
ip route 10.10.102.0 255.255.255.0 Vlan102
ip route 10.10.102.1 255.255.255.255 Vlan102
ip route 10.10.102.253 255.255.255.255 Integrated-Service-Engine0/0
ip route 10.10.102.253 255.255.255.255 Vlan102
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
destination-pattern 399
b2bua
session protocol sipv2
session target ipv4:10.10.102.253
voice-class sip outbound-proxy ipv4:10.10.102.253
dtmf-relay sip-notify
codec g711ulaw
no vad
Xavier
ā02-18-2013 08:04 AM
Update CUE software and check again.
ā02-18-2013 08:41 AM
I already have the 8.6.3 and I can only find the 8.6.1 on Cisco web site. Do you know where I can find the 8.6.5 ?
ā02-18-2013 08:42 AM
If I am not mistaken SWP 8.6.1 contains CUE 8.6.5 (SWP version numbers and CME/CUE versions don't always line up).
ā02-18-2013 11:28 AM
You are right. I checked the package and there is the CUE 8.6.5 inside. I will upgrade the IPBX.
Thanks.
ā02-25-2013 07:58 AM
I upgraded to 8.6.5 and I still have the same issue ? Any idea ?
I debugged the rtp error and I have this message :
:rtp_udp_unreachable:Entered: ICMP unreachable for dest(10.10.102.253(16699)), src(10.10.102.1(20879))
It seems that I can't reach the integrated service engine with rtp but I can ping it. Any idea ?
ā02-25-2013 01:43 PM
Hello Xavier,
I believe that it will be easier to resolve the issue if you open a case for this and get the system checked.
Best regards,
Alex
ā02-25-2013 04:23 PM
That is possibly related to RTCP packets, that are not supported and elict ICMP. But unrelated to the original problem.
ā02-26-2013 12:28 AM
I would like to open a case but I'm in Morocco and Cisco is not selling anymore Smartnet for UC560 in this country. My reseller asked to Cisco in Morocco but for the moment no answer.
From the configuration given above, I modified the routing table below :
With the route "ip route 10.10.102.253 255.255.255.255 Vlan102" I can ping the ISE interface, call the voicemail and the auto-attendant but I can't record a message.
When I remove "ip route 10.10.102.253 255.255.255.255 Vlan102", I can't ping ISE interface. Did I miss something with the "ip unnumbered" command ?
I checked the routing table on the service-module and it's OK.
Best regards,
ā02-26-2013 02:28 AM
On the UC560, you should not need any static IP route for CUE.
You will see there is currently a bug, CSCub52837, so that first ping and other packets are dropped after a timout, yet it functions normally.
