how to configure ip phone 7975 as a teleworker phone?
ismaelcolon
Hello everyone i am very new to cisco and have been testing out the capabilities of our UC520. i am having trouble finding documentation on how to configure an IP phone for a teleworker who will be bringing a phone home and connecting it to their dsl/cable, and then the phone being able to find its way to our UC520. I am looking for some config examples, i do have an ASA5510, if that helps. Any suggestions will be helpful.
Patrick Born
This part of the community is specifically for support of SPA9000 IP PBX and related phones and ATAs.
You'll probably have better luck at the UC500 community at:
https://www.myciscocommunity.com/community/smallbizsupport/voiceandconferencing/sbcs-uc500?view=discussionsSBCS/UC500
Patrick
Hi Ismael,
It can certainly be done. Please review the following VoD for instructions on how to do this, additional material and supported features:
https://supportforums.cisco.com/docs/DOC-10460
Marcos
ismaelcolon
ok, thanks Pat and Marcos, i will look at those VoD, thanks for the quick reply.
