ā11-29-2012 04:22 PM - edited ā03-21-2019 06:40 AM
Is it possible to connect a 7825-I4 Call Manger and a BE3000 through SIP trunks?
Luis Noriega
Solved! Go to Solution.
ā11-30-2012 08:47 AM
If the BE3K & CUCM are in the same LAN, you should not require a CUBE. If they are in different locations, you can use CUBE for things like CAC.
There are dial plan changes required for calls to route over SIP trunk between the two systems. The application note will cover that and other configuration items on CUCM.
ā11-30-2012 02:16 AM
It is not officially supported yet.
This is something which we are targeting for next release where we will publish an Application Note to help with the integration.
ā11-30-2012 07:36 AM
Thank you Sanjay.
It is not possible trough 2800 routers and CUBE?
Luis Noriega
