11-11-2010 09:20 PM - edited 03-21-2019 03:16 AM
Running Server 2.0.0.89b, Operator 1.6.0.16, using 525G phone.
After logging into operator, says "The phone has been disconnected. Status Code:-1.
How can I fix?
PS. I get same message when trying to use 504G phone, which I KNOW is not supported as Operator phone.
** I'm 50 minutes away from Operator tng @ customer site & now this install is doing same thing!! Different pc & 7962 phone!!
Solved! Go to Solution.
11-12-2010 09:49 PM
Have you tried restarting the SCC server services? That can help with these situations.
If the problem persists, issue a show ephone and see if the server has an open TAPI connection to that phone you are trying to control.
11-12-2010 09:49 PM
