SPA112&SPA122 support H323 ?
potan
Hi ;
May i know SPA112 and SPA122 able support H323 protocol ?
From the technical spec or data sheet, i don;t see. If can, need to upgrade firmware ? Pls advice. Thanks.
rgds
tan
cchamorr
Level 5
Level 5
The SPA1xx devices are SIP only and don't support H323.
From the admin guide:
"The ATAs use the Session Initiation Protocol (SIP) open standard so there is little or no involvement by a “middle-man” server or media gateway controller. SIP allows inter-operation with all ITSPs that support SIP. "
Please don't forget to mark an answer as correct if it was helpful to you so that other members can benefit from it.
I hope this helps.
cchamorr
Level 5
Level 5
I hope this helps.
