SPA525G2 firmware 7.4.9 and CCA
Jeremy Koch
hello, so the latest firmware for the SPA525G2 is 7.4.9a. there is also the bluetooth version as well...
when dragging either of these files to my UC540 in CCA3.1.1 do i need to change the file names and remove the 'a' or the 'a-bt'???
if i drag them the uc540 currently, they end up in the right folder but the CCA reports an error saying that part of the file name was not resolved or recognised...(cant remeber exactly as im at home now and not infront of the machine)
thanks
UC540 system with 8.6.2 Software Pack
Jeremy Koch
ok so i worked it out myself...all you do is remove the last few characters to make the version end with a nine. if your 525 has no BT then use the 'a' firmware and rename the file removing the 'a' on the end. if you 525 has BT then use the 'a-bt' file and remove those characters.
once you have done this, drag the file to the uc500 in CCA and it will upload.
reboot your phones and hey presto! all done
