Trying to reload a Cisco UC 520, CUE, only, the CF card went bad, I replaced it.
There were no backups
Using cli, I did a service-module integrated-Service-Engine 0/0 reload and confirm, then service-module integrated-Service-Engine 0/0 session
config
then boot helper
I get bad magic number, see below
I think I have the wrong PKG file, Cisco web site does not have a download for a download specifically for a 520, which is what I need , I think
Any one know where I can get one ?
ServicesEngine boot-loader>
ServicesEngine boot-loader> ?
? - alias for 'help'
boot - boot from specified src
config - configure various params
help - print online help
ping - send ICMP ECHO_REQUEST to network host
reboot - Perform RESET of the CPU
show - show config, trace or version
verify - verify software versions
ServicesEngine boot-loader> config
IP Address [10.1.10.1] >
Subnet Mask [255.255.255.252] >
TFTP Server [192.168.1.15] >
Gateway [10.1.10.2] >
Default Helper-file [cue-vm-k9.uc500.8.6.5.pkg] > cue-vm-k9.uc500.8.0.3.pkg
Ethernet Interface [internal] [internal] >
Default Boot [none|helper|disk] [disk] >
Default Bootloader [primary|secondary] [primary] >
Erasing Flash...
. done
Erased 1 sectors
Writing to Flash...
64 KBdone
ServicesEngine boot-loader> boot helper
bl_boot_helper_cmd tftpboot 0x4000000 cue-vm-k9.uc500.8.0.3.pkg
Using internal device
TFTP from server 192.168.1.15; our IP address is 10.1.10.1; sending through gateway 10.1.10.2
Filename 'cue-vm-k9.uc500.8.0.3.pkg'.
Load address: 0x4000000
Loading: ###################################################
done
Bytes transferred = 260703 (3fa5f hex)
bl_boot_helper_cmd root=/dev/ram rw ramdisk_size=64000 ip=10.1.10.1:192.168.1.15:10.1.10.2:255.255.255.252::eth0:off console=ttyS0,9600 initrd=04000000,4000000 install_root=ide plat=freddo
## Booting image at 04000000 ...
Bad Magic Number
Usage:
boot <helper | disk>
