UC500 behind sonicwall
Jeremy Lizzotte
                   Hello guys, i know i have seen numerous documents and FAQs for SA520s, but i need to look for help in setting up a UC500/300 behind a sonicwall tz210.  im a cisco guy not a sonicwall guy and i know the sa talks about static routes and all.  Thanks for the help.
David Trad
Hi Jermeny,
It would be very much helpful if you can tell us what you are trying to achieve, I.E even a network diagram would go a long way
Will there be SIP trunking taking place?
Will the UC-500 be doing the routing or will you have the Sonic do it?
What is your DHCP server?
How many VLAN's will you have or will it just be the standard 2 VLAN's on the UC-500?
Any further information you can provide would be good.
Cheers,
David Trad.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
Jeremy Lizzotte
Yes, there will be SIP Trunk, the UC would not do routing except for phones VLAN100. The DCHP server would be the sonicwall (i could set the phones up staticly). the
Cisco CCA suggested settings:
Note:  All IPs used are suggested, use your own scheme.
1.     Configure > Routing > IP Addresses
          Set VLAN1 IP to same as internal network
               (i.e. if internal network is 192.168.100.1 set VLAN1 IP to 192.168.100.15)
          Set VLAN100 for phone network, 10.1.1.1
          a.     Device configuration page
                    Set Domain Name to SIP provider domain, i.e. att.com
                    Enable Domain Lookup
                    Enter DNS servers, i.e. 8.8.8.8 and 4.2.2.1 (Google DNS servers)
2.      Configure > Routing > Internet Connection
          Modify FastEthernet
               Select Static IP
                    IP Address - 192.168.101.2
                    Subet - 255.255.255.252
                    Default Gateway - 192.168.101.1
                    Primary DNS - 8.8.8.8
                    2nd DNS - 4.2.2.1
Sonicwall suggested settings:
1.     Connect UC500 to port X3 on Sonicwall.
2.     Go to Network > Interfaces
             Config X3 port:
                  Change Zone to DMZ
                  IP Assignment - Static
                  IP address - i.e. 192.168.101.1
                  Subnet Mask - 255.255.255.252
3.     Go to VoIP > Settings:
          Enable conistent NAT
          Enable SIP Transformations
            Permit non-SIP packets...
            Enable SIP Back-to-Back...
