03-11-2013 05:57 AM - edited 03-21-2019 07:05 AM
after update our UC520 to the Software Pack 8.6.1 I have a problem with IP Phone CP-7937G. I reboot the Phone and I get the message on the phone display "Change language" and the phone will automatically start again and again?
I have install two locale packs UC500_8.6.1_locale_de_DE.zip, UC500_8.6.1_locale_en_US.zip and the default Phone locale is German.
My Software Versions
Software Verison: 15.1(4)M5
Software Pack: 8.6.1
IOS: uc500-advipservicesk9-mz.151-4.M5
CME: 8.6
Voicemail: 8.6.5
All other IP Phones 7961...works fine. Can everbody help me?
Solved! Go to Solution.
03-12-2013 02:45 AM
Hello Jochen,
Please run the following command:
dir flash:/its | i .jar
if the output looks like the following:
251 -rw- 69843 Nov 20 2012 20:37:24 +01:00 user_define_4_rp-sccp.jar
Please add the following under config mode:
(config)# tftp-server flash:/its/user_define_4_rp-sccp.jar
if it is user_define_5_ just change accordingly.
HTH,
Alex
*Please rate helpful posts
03-12-2013 04:27 AM
Helllo Jochen,
Yes, you can and it is recommended if now the phone is working.
Best regards,
Alex
03-12-2013 12:59 AM
Any ideas?
03-12-2013 02:45 AM
Hello Jochen,
HTH,
Alex
03-12-2013 02:49 AM
I can solved the problem. I have read this post:
https://supportforums.cisco.com/message/3794925#3794925
and this solved my problem.
I do this:
262 -rw- 74885 Mar 11 2013 12:20:34 +01:00 user_define_4_gp-sccp.jar
263 -rw- 61913 Mar 11 2013 12:20:36 +01:00 user_define_4_ipc-sccp.jar
267 -rw- 71712 Mar 11 2013 12:20:38 +01:00 user_define_4_tc-sccp.jar
265 -rw- 69770 Mar 11 2013 12:20:38 +01:00 user_define_4_rp-sccp.jar
260 -rw- 61838 Mar 11 2013 12:20:34 +01:00 user_define_4_be-sccp.jar
264 -rw- 61653 Mar 11 2013 12:20:36 +01:00 user_define_4_mk-sccp.jar
268 -rw- 61913 Mar 11 2013 12:20:40 +01:00 user_define_4_td-sccp.jar
after that I register my IP Phone 7937G and restart the phone. After the restart the phone comes up and working correctly with the German locale.
Can someone explain to me what does the above command do?
Thank you!
03-12-2013 04:10 AM
Hello Jochen,
Thank you for the rating.
This adds the specified file to the TFTP with correct path.
Best regards,
Alex
03-12-2013 04:18 AM
Hi Alexander,
can I "write" the config after this command:
03-12-2013 04:27 AM
Helllo Jochen,
Best regards,
Alex
