UC520 Vitelity.net configuration
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
03-01-2013 05:38 AM - edited 03-21-2019 07:02 AM
You guys have probably seen this thousands of times, but I cannot seem to figure it out.
I have an account at vitelity.net and I am trying to setup the trunk on my UC520. the UC520 is connected directly to the internet (i.e. dynamic ip with no firewall). No matter what I do I cannot get an inbound call but I can call outbound all day. When I attempt to call the number I get an immediate busy signal.
I'm new to voice. Feel free to ask for any logs you desire.
- Labels:
Voice Systems
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-01-2013 06:15 AM
Without more information, my guess would be that your provider is rejecting the call, because they don't recognize or allow the caller ID number you are using.
You need to have a translation rule in place to change your outgoing caller ID to your incoming phone number.
If you are using CCA:
Configure > Telephony > Dial Plan > Outgoing - then go to the "Caller ID" tab at the top.
If you are using CLI:
You will need to apply a tranlation rule to your outgoing dial-peers to translate the "calling" number to your phone number.
The other possibility is that your provider is rejecting the call because it is not coming from an IP address they recognize. It really depends how your provider is setup.
Thank you,
Darren
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-01-2013 06:16 AM
The trouble is incoming calls not outgoing. I can call just fine, but I cannot RECEIVE calls.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-01-2013 06:19 AM
Sorry, I read that wrong..
Do you have a DID specified for the incoming calls? Where are they being directed?
Thank you,
Darren
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-01-2013 06:24 AM
Yes. Maybe I did it incorrectly? I Have a UC520 with 8.6.1 running default config. I ran the wizard and added the discovered phone (201) to the system. I've set my sip trunk good enough to register and call out - I just can't receive calls.
I've set the destination for the DID to the 201 extention. Should I send it to an autoattendant in CCA?
Need more info, please ask.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-01-2013 06:35 AM
The only way to know for sure what is happening, is to run a few debugs to see what is happening to the call.
Debugs I would run:
debug voice ccapi inout
debug ccsip messages
Thank you,
Darren
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-01-2013 06:41 AM
before I post the logs, is there anything I should remove from them? I wouldn't want someone to simply get the config and load my credentials for example.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-01-2013 07:34 AM
Posting your debugs should not be an issue.
If you are posting your running configuration, there are things that should be removed, or X'd out.
Thank you,
Darren
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-07-2013 08:18 AM
Good morning
Hi guys, thanks for using our forum, my name is Johnnatan and I am part of the Small business Support community. Maybe this post could help your problem: https://supportforums.cisco.com/message/3869172#3869172
I hope you find this answer useful,
*Please mark the question as Answered or rate it so other users can benefit from it"
Greetings,
Johnnatan Rodriguez Miranda.
Cisco Network Support Engineer.
