08-21-2011 09:07 AM - edited 03-21-2019 04:32 AM
Dear All,
I would like create outbound voice translation rule for called number. I want to replace #1 to 91521.
The following is my translation rule:
Voice translation rule 1
Rule 1 /#1/ /91521/
user dial: #123457 translate to 9152123457
I using test voice translation rule to test the translation and it show translation correct.
How do i put the destination pattern in dial peer to make the translation rule work?
Because when user make a call, UC 520 will use dial peer before translation rule.
Kindly advice.
Spana
08-21-2011 03:31 PM
Hi Spana,
If you upgrade to CCA 3.1 you can make use of the new Call-Back setup process feature that was just recently introduced, this will create the translation rules/profiles and apply them to their appropriate places.
If you are doing this via CLI, you will need to tell us what type of trunks are being used, this will determine to a degree where you apply this rule, but for now it would seem this is something you need to apply to a dial-peer anyway.
Can you confirm if this is also a CLI built system or a CCA built and managed system.
Cheers,
David.
08-22-2011 07:40 AM
David,
Thank you so much for the reply.
The interface is E1 for PSTN outgoing call. I using CLI to configure the voice translation rule and apply to dial peer.
I would like to seek your assistant, what destination pattern i need to specify in order the translation rule can modified the called number.
Lum
08-22-2011 04:53 PM
Hi Lum,
Can you please post your running configuration file, please make sure to remove any sensitive data.
When you post this, also provide a complete explination of what it is exactly you want to achieve so I can try and follow the process or methodology of your configuration, it would make it quicker for me to get the gist of things and then put forward some recommendations.
Cheers,
David.
08-23-2011 06:32 PM
Hi David,
The following is the show run config for my UC520. I trying to achieve is using the translation rule to modify the called number when users budget call for internation outbound call. Currently using need dial 9152101....... and I want user dial a #012234567 translation will convert the number to 91521012234567.
Current configuration : 41529 bytes
! Last configuration change at 14:46:11 GMT Mon Jul 11 2011 by salmon
! NVRAM config last updated at 10:31:00 GMT Tue Aug 16 2011
version 12.4
parser config cache interface
parser config interface
no service pad
service internal
service compress-config
service sequence-numbers
hostname UC520
boot-start-marker
boot-end-marker
card type e1 0 2
--More-- logging buffered 4096
aaa new-model
aaa authentication login h323 local
aaa authorization exec h323 local
aaa authorization network h323 local
aaa session-id common
clock timezone GMT 8
network-clock-participate wic 2
network-clock-select 1 E1 0/2/0
crypto pki trustpoint TP-self-signed-2238489612
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2238489612
revocation-check none
rsakeypair TP-self-signed-2238489612
--More-- ip cef
ip dhcp relay information trust-all
ip dhcp use vrf connected
stcapp ccm-group 1a
stcapp
stcapp feature access-code
isdn switch-type primary-net5
voice call send-alert
voice rtp send-recv
voice service voip
--More-- allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
h323
call start slow
sip
no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g728
codec preference 4 g729br8
voice class custom-cptone leavetone
dualtone conference
frequency 400 800
cadence 400 50 200 50 200 50
voice class custom-cptone jointone
dualtone conference
frequency 600 900
cadence 300 150 300 100 300 50
voice class custom-cptone SGCustom
dualtone disconnect
frequency 400 400
cadence 200 200
voice translation-rule 2
rule 1 /1234567/ /8005/
rule 2 /2234556/ /8005/
rule 3 /3333333/ /8808/
rule 4 /4444444/ /8809/
rule 5 /5555555/ /8700/
rule 8 /6666666/ /88/
voice translation-rule 3
rule 1 /^88/ /90/
voice translation-rule 4
rule 1 /2223333/ /8005/
rule 5 /^63344/ /8/
voice translation-rule 5
rule 1 /^\(.*\)/ /9\1/
voice translation-rule 6
rule 1 /[*][8][1]\(.*\)/ /9\1/
voice translation-rule 7
rule 1 /[*][8][6]\(.*\)/ /9\1/
rule 2 /[*][8][7]\(.*\)/ /9\1/
voice translation-rule 1112
--More-- rule 1 /^9/ //
voice translation-rule 2222
rule 1 /^91900/ //
rule 2 /^991900/ //
voice translation-rule 8099
rule 1 /8099/ //
voice translation-profile 8099
translate called 8099
voice translation-profile CallBlocking
translate called 2222
voice translation-profile IncomingPOTS
translate called 4
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate calling 1111
translate called 1112
--More-- voice translation-profile TollbyPass
translate called 6
voice translation-profile TollbyPasstoChina
translate called 7
voice translation-profile append9
translate calling 5
voice translation-profile incomingDID
translate calling 5
translate called 2
voice translation-profile outgoingDID
translate calling 3
voice-card 0
no dspfarm
dsp services dspfarm
application
--More-- service clid_col_npw_npw
param uid-len 4
username 999
username salmon privilege 15 secret 5 $1$6XKW$WlXQM3VfZKW.HoeXmKS/W/
username cisco123 privilege 15 secret 5 $1$IKsB$NHmLxX.X/2T8CEajxm4og1
archive
log config
logging enable
logging size 600
hidekeys
controller E1 0/2/0
pri-group timeslots 1-30
interface Loopback0
--More-- description $FW_INSIDE$
ip address 1.1.1.1 255.255.255.252
ip virtual-reassembly
interface FastEthernet0/0
description $FW_OUTSIDE$
ip address dhcp
ip access-group 104 in
ip nat outside
duplex auto
speed auto
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group
ip unnumbered Loopback0
ip nat inside
service-module ip address 1.1.1.1 255.255.255.252
service-module ip default-gateway 1.1.1.2
interface FastEthernet0/1/0
macro description cisco-phone | cisco-phone $access_vlan 1
--More-- !
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
interface FastEthernet0/1/7
interface FastEthernet0/1/8
--More-- macro description cisco-phone | cisco-phone $access_vlan 1
interface Serial0/2/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface Vlan1
ip address 1.1.1.1 255.255.255.0
ip route 0.0.0.0 0.0.0.0 1.1.1.3
ip route 1.1.1.2 255.255.255.255 Integrated-Service-Engine0/0
ip http server
ip http authentication local
ip http secure-server
ip http path flash:
ip nat inside source list 1 interface FastEthernet0/0 overload
--More-- snmp-server community public RO
tftp-server APPS-1.0.3.SBN
tftp-server apps11.8-2-2TR2.sbn
tftp-server apps31.8-2-2TR2.sbn
tftp-server apps41.8-2-2TR2.sbn
tftp-server apps70.8-2-2TR2.sbn
tftp-server cmterm_7936.3-3-13-0.bin
tftp-server cnu11.8-2-2TR2.sbn
tftp-server cnu31.8-2-2TR2.sbn
tftp-server cnu41.8-2-2TR2.sbn
tftp-server cnu70.8-2-2TR2.sbn
tftp-server CP7902080002SCCP060817A.sbin
tftp-server CP7921G-1.0.3.LOADS
tftp-server cvm11sccp.8-2-2TR2.sbn
tftp-server cvm31sccp.8-2-2TR2.sbn
tftp-server cvm41sccp.8-2-2TR2.sbn
tftp-server cvm70sccp.8-2-2TR2.sbn
tftp-server dsp11.8-2-2TR2.sbn
tftp-server dsp31.8-2-2TR2.sbn
--More-- tftp-server dsp41.8-2-2TR2.sbn
tftp-server dsp70.8-2-2TR2.sbn
tftp-server GUI-1.0.3.SBN
tftp-server jar11sccp.8-2-2TR2.sbn
tftp-server jar31sccp.8-2-2TR2.sbn
tftp-server jar41sccp.8-2-2TR2.sbn
tftp-server jar70sccp.8-2-2TR2.sbn
tftp-server P00308000500.bin
tftp-server P00308000500.loads
tftp-server P00308000500.sb2
tftp-server P00308000500.sbn
tftp-server S00105000200.sbn
tftp-server SCCP11.8-2-2SR2S.loads
tftp-server SCCP31.8-2-2SR2S.loads
tftp-server SCCP41.8-2-2SR2S.loads
tftp-server SCCP70.8-2-2SR2S.loads
tftp-server SYS-1.0.3.SBN
tftp-server term06.default.loads
tftp-server term11.default.loads
tftp-server term31.default.loads
tftp-server term41.default.loads
tftp-server term61.default.loads
tftp-server term70.default.loads
--More-- tftp-server term71.default.loads
tftp-server TNUX-1.0.3.SBN
tftp-server TNUXR-1.0.3.SBN
tftp-server WLAN-1.0.3.SBN
tftp-server flash:SCCP42.8-3-2S.loads
tftp-server flash:SCCP45.8-3-2S.loads
tftp-server flash:SCCP75.8-3-2S.loads
tftp-server flash:apps42.8-3-1-22.sbn
tftp-server flash:apps45.8-3-1-22.sbn
tftp-server flash:apps75.8-3-1-22.sbn
tftp-server flash:cnu42.8-3-1-22.sbn
tftp-server flash:cnu45.8-3-1-22.sbn
tftp-server flash:cnu75.8-3-1-22.sbn
tftp-server flash:cvm42sccp.8-3-1-22.sbn
tftp-server flash:cvm45sccp.8-3-1-22.sbn
tftp-server flash:cvm75sccp.8-3-1-22.sbn
tftp-server flash:dsp42.8-3-1-22.sbn
tftp-server flash:dsp45.8-3-1-22.sbn
tftp-server flash:dsp75.8-3-1-22.sbn
tftp-server flash:jar42sccp.8-3-1-22.sbn
tftp-server flash:jar45sccp.8-3-1-22.sbn
tftp-server flash:jar75sccp.8-3-1-22.sbn
tftp-server flash:term42.default.loads
--More-- tftp-server flash:term45.default.loads
tftp-server flash:term62.default.loads
tftp-server flash:term65.default.loads
tftp-server flash:term75.default.loads
tftp-server DistinctiveRingList.xml
tftp-server RingList.xml
tftp-server flash:AreYouThereF.raw
tftp-server flash:Bass.raw
tftp-server flash:CallBack.raw
tftp-server flash:Chime.raw
tftp-server flash:Classic1.raw
tftp-server flash:Classic2.raw
tftp-server flash:ClockShop.raw
tftp-server flash:Drums1.raw
tftp-server flash:Drums2.raw
tftp-server flash:FilmScore.raw
tftp-server flash:HarpSynth.raw
tftp-server flash:Jamaica.raw
tftp-server flash:KotoEffect.raw
tftp-server flash:MusicBox.raw
tftp-server flash:Piano1.raw
tftp-server flash:Piano2.raw
tftp-server flash:Pop.raw
--More-- tftp-server flash:Pulse1.raw
tftp-server flash:Ring1.raw
tftp-server flash:Ring2.raw
tftp-server flash:Ring3.raw
tftp-server flash:Ring4.raw
tftp-server flash:Ring5.raw
tftp-server flash:Ring6.raw
tftp-server flash:Ring7.raw
tftp-server flash:Sax1.raw
tftp-server flash:Sax2.raw
tftp-server flash:Vibe.raw
tftp-server flash:Analog1.raw
tftp-server flash:Analog2.raw
tftp-server flash:AreYouThere.raw
tftp-server CP7912080004SCCP080108A.sbin
tftp-server SCCP75.8-3-5S.loads
tftp-server jar75sccp.8-3-4-16.sbn
tftp-server dsp75.8-3-4-16.sbn
tftp-server cvm75sccp.8-3-4-16.sbn
tftp-server cnu75.8-3-4-16.sbn
tftp-server apps75.8-3-4-16.sbn
tftp-server Desktops320x212x12List.xml
tftp-server Desktops320x212x16List.xml
--More-- tftp-server Desktops320x216x16List.xml
tftp-server Desktops/320x216x16/List.xml
tftp-server Desktops/320x212x16/List.xml
tftp-server Desktops/320x212x12/List.xml
control-plane
--More-- !
voice-port 0/0/0
ren 3
caller-id enable
voice-port 0/0/1
caller-id enable
voice-port 0/0/2
caller-id enable
voice-port 0/0/3
caller-id enable
voice-port 0/2/0:15
bearer-cap Speech
voice-port 0/1/0
supervisory disconnect dualtone pre-connect
supervisory custom-cptone SGCustom
timeouts wait-release 2
caller-id enable
--More-- voice-port 0/1/1
shutdown
caller-id enable
voice-port 0/1/2
shutdown
caller-id enable
voice-port 0/1/3
shutdown
caller-id enable
voice-port 0/3/0
shutdown
caller-id enable
--More-- !
voice-port 0/3/1
shutdown
caller-id enable
voice-port 0/3/2
shutdown
caller-id enable
voice-port 0/3/3
shutdown
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
shutdown
description Music On Hold Port
sccp local Loopback0
sccp ccm 10.65.10.8 identifier 100 version 4.0
sccp
--More-- !
sccp ccm group 1
associate ccm 100 priority 1
associate profile 1 register confprof1
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum conference-participants 16
maximum sessions 1
conference-join custom-cptone jointone
conference-leave custom-cptone leavetone
associate application SCCP
dial-peer cor custom
name internal
name local
name domestic
name international
--More-- !
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-domestic
member domestic
dial-peer cor list call-international
member international
dial-peer cor list user-internal
member internal
dial-peer cor list user-local
member internal
member local
dial-peer cor list user-domestic
member internal
--More-- member local
member domestic
dial-peer cor list user-international
member internal
member local
member domestic
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 2001 voip
description ** cue voicemail number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 600
b2bua
session protocol sipv2
session target ipv4:1.1.1.1
--More-- dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 202 voip
description ** US and Canada **
destination-pattern 3[2-4]..
b2bua
voice-class codec 1
session target ipv4:2.2.2.2
dtmf-relay cisco-rtp
no vad
dial-peer voice 203 voip
b2bua
voice-class codec 1
session target ipv4:3.3.3.3
no vad
--More-- !
dial-peer voice 204 voip
destination-pattern 72..
b2bua
voice-class codec 1
session target ipv4:4.4.4.4
no vad
dial-peer voice 205 voip
b2bua
voice-class codec 1
session target ipv5.5.5.5
no vad
dial-peer voice 500 pots
destination-pattern 91900T
--More-- !
dial-peer voice 10 pots
corlist outgoing call-local
description ** E1 pots dial-peer **
translation-profile outgoing outgoingDID
destination-pattern 9[2-9]T
port 0/2/0:15
no sip-register
dial-peer voice 11 pots
translation-profile incoming incomingDID
incoming called-number .
direct-inward-dial
port 0/2/0:15
dial-peer voice 12 pots
corlist outgoing call-international
destination-pattern 9019T
port 0/2/0:15
prefix 018
no sip-register
--More-- !
dial-peer voice 13 pots
destination-pattern 9001T
port 0/2/0:15
prefix 018
no sip-register
dial-peer voice 14 pots
destination-pattern 91513T
port 0/2/0:15
prefix 1513
no sip-register
dial-peer voice 15 pots
--More-- destination-pattern 91551T
port 0/2/0:15
prefix 1551
no sip-register
dial-peer voice 16 pots
destination-pattern 9011T
port 0/2/0:15
prefix 018
no sip-register
dial-peer voice 17 pots
destination-pattern 9119T
port 0/2/0:15
prefix 119
no sip-register
dial-peer voice 2 pots
--More-- preference 9
destination-pattern 12345678
port 0/2/0:15
dial-peer voice 206 voip
description ** Scotland **
destination-pattern 5...
b2bua
voice-class codec 1
session target ipv4:10.44.2.1
no vad
dial-peer voice 200 voip
description ** Norway Dial-Peer **
destination-pattern 2...
b2bua
voice-class codec 1
session target ipv4:6.6.6.6
no vad
--More-- dial-peer voice 201 voip
b2bua
voice-class codec 1
session target ipv4:7.7.7.7
no vad
dial-peer voice 210 voip
description Auto Attendant
destination-pattern 8700
b2bua
voice-class codec 1
session target ipv4:8.8.8.8
no vad
dial-peer voice 211 voip
description ** Voice Mail Pilot **
destination-pattern 8600
--More-- b2bua
voice-class codec 1
no vad
dial-peer voice 212 voip
translation-profile incoming 8099
destination-pattern 8099
session target ipv4:10.65.10.8
incoming called-number 8099
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 18 pots
destination-pattern 91800T
--More-- direct-inward-dial
port 0/2/0:15
prefix 1800
no sip-register
dial-peer voice 19 pots
destination-pattern 9018T
port 0/2/0:15
prefix 018
no sip-register
dial-peer voice 20 pots
destination-pattern 91521T
port 0/2/0:15
prefix 018
no sip-register
--More-- dial-peer voice 207 voip
description VoIP to Japan
destination-pattern 81..
b2bua
voice-class codec 1
session target ipv4:9.9.9.9
no vad
dial-peer voice 208 voip
translation-profile outgoing TollbyPass
destination-pattern *81T
b2bua
voice-class codec 1
session target ipv4:10.10.10.10
no vad
dial-peer voice 213 voip
description ***VOIP to China Beijing****
destination-pattern 86..
--More-- b2bua
session target ipv4:11.11.11.11
codec g711ulaw
no vad
dial-peer voice 214 voip
description ***VOIP to China ShangHai****
destination-pattern 87..
b2bua
session target ipv4:12.12.12.12
codec g711ulaw
no vad
dial-peer voice 215 voip
description ***TollByPass to CH-SH***
translation-profile outgoing TollbyPasstoChina
destination-pattern *87T
b2bua
voice-class codec 1
--More-- session protocol sipv2
session target ipv4:13.13.13.13
no vad
dial-peer voice 216 voip
description ***TollBypass to CH-BJ***
destination-pattern *86T
b2bua
voice-class codec 1
session target ipv4:14.14.14.14
no vad
dial-peer voice 217 voip
description **SG-Chile DialPeer**
no dial-peer outbound status-check pots
--More-- telephony-service
sdspfarm conference mute-on 111 mute-off 222
sdspfarm units 1
sdspfarm tag 1 confprof1
conference hardware
video
max-ephones 40
max-dn 160
ip source-address 10.65.10.8 port 2000
auto assign 10 to 43
calling-number initiator
service phone videoCapability 1
timeouts interdigit 5
system message ************
url services http://1.1.1.1/voiceview/common/login.do
url authentication http://1.1.1.1/voiceview/authentication/authenticate.do
time-zone 43
date-format dd-mm-yy
voicemail 600
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh music-on-hold.au
--More-- multicast moh 239.10.16.16 port 2000
web admin system name cisco secret 5 $1$5tuu$iVGyYJCjtbmIItBw7rq59.
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
secondary-dialtone 9
directory entry 1 2150 name JJ
create cnf-files version-stamp 7960 May 30 2011 17:25:39
08-24-2011 04:18 PM
Hi Lum,
OK I understand what you are trying to achieve now... From what I can gather you are wanting to do Toll Bypass, which usually is a reasonably easy thing to do.
Toll Bypass is normally controlled by Dial Peers not translation rule, and it is called and "Over Ride" code and is prefixed to an international Dial-peer, but you can no longer do this with CCA or at least I am unaware of how you do it in CCA with the current version, although I do see ones for Australia in CCA now that are pre-programmed, and if you do it via CLI, CCA may delete this dial-peer or have heart failure when it goes to parse the configuration information.
I am going to book in some time to work this up on a LAB bench and see if there is a way to do this via Translation Rules/Profiles without having to do it via CLI and get CCA to do it so that way the configuration is an approved one...
I will need some time on this, so if urgency is of utmost importance to you then please log a case with SBCS and get the ball rolling with them, otherwise sit tight whilst I try and work out how to do this for you.
Cheers,
David.
